Hi everybody,
Let me describe what I have done.
I have compiled using Eclipse.
My sdkconfig file is the following
# Automatically generated file; DO NOT EDIT.
# Espressif IoT Development Framework Configuration
# SDK tool configuration
CONFIG_TOOLPREFIX="xtensa-esp32-elf-"
CONFIG_PYTHON="python"
# Bootloader config
# CONFIG_LOG_BOOTLOADER_LEVEL_NONE is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_ERROR is not set
CONFIG_LOG_BOOTLOADER_LEVEL_WARN=y
# CONFIG_LOG_BOOTLOADER_LEVEL_INFO is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_DEBUG is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_VERBOSE is not set
CONFIG_LOG_BOOTLOADER_LEVEL=2
# Security features
# CONFIG_SECURE_BOOT_ENABLED is not set
# CONFIG_FLASH_ENCRYPTION_ENABLED is not set
# Serial flasher config
CONFIG_ESPTOOLPY_PORT="COM6"
# CONFIG_ESPTOOLPY_BAUD_115200B is not set
CONFIG_ESPTOOLPY_BAUD_230400B=y
# CONFIG_ESPTOOLPY_BAUD_921600B is not set
# CONFIG_ESPTOOLPY_BAUD_2MB is not set
# CONFIG_ESPTOOLPY_BAUD_OTHER is not set
CONFIG_ESPTOOLPY_BAUD_OTHER_VAL=115200
CONFIG_ESPTOOLPY_BAUD=230400
# CONFIG_ESPTOOLPY_COMPRESSED is not set
# CONFIG_ESPTOOLPY_FLASHMODE_QIO is not set
# CONFIG_ESPTOOLPY_FLASHMODE_QOUT is not set
CONFIG_ESPTOOLPY_FLASHMODE_DIO=y
# CONFIG_ESPTOOLPY_FLASHMODE_DOUT is not set
CONFIG_ESPTOOLPY_FLASHMODE="dio"
# CONFIG_ESPTOOLPY_FLASHFREQ_80M is not set
CONFIG_ESPTOOLPY_FLASHFREQ_40M=y
# CONFIG_ESPTOOLPY_FLASHFREQ_26M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_20M is not set
CONFIG_ESPTOOLPY_FLASHFREQ="40m"
# CONFIG_ESPTOOLPY_FLASHSIZE_1MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE_2MB=y
# CONFIG_ESPTOOLPY_FLASHSIZE_4MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_8MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_16MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE="2MB"
CONFIG_ESPTOOLPY_FLASHSIZE_DETECT=y
CONFIG_ESPTOOLPY_BEFORE_RESET=y
# CONFIG_ESPTOOLPY_BEFORE_NORESET is not set
# CONFIG_ESPTOOLPY_BEFORE_ESP32R0 is not set
CONFIG_ESPTOOLPY_BEFORE="default_reset"
CONFIG_ESPTOOLPY_AFTER_RESET=y
# CONFIG_ESPTOOLPY_AFTER_NORESET is not set
CONFIG_ESPTOOLPY_AFTER="hard_reset"
# CONFIG_MONITOR_BAUD_9600B is not set
# CONFIG_MONITOR_BAUD_57600B is not set
CONFIG_MONITOR_BAUD_115200B=y
# CONFIG_MONITOR_BAUD_230400B is not set
# CONFIG_MONITOR_BAUD_921600B is not set
# CONFIG_MONITOR_BAUD_2MB is not set
# CONFIG_MONITOR_BAUD_OTHER is not set
CONFIG_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_MONITOR_BAUD=115200
# Partition Table
CONFIG_PARTITION_TABLE_SINGLE_APP=y
# CONFIG_PARTITION_TABLE_TWO_OTA is not set
# CONFIG_PARTITION_TABLE_CUSTOM is not set
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_CUSTOM_APP_BIN_OFFSET=0x10000
CONFIG_PARTITION_TABLE_FILENAME="partitions_singleapp.csv"
CONFIG_APP_OFFSET=0x10000
CONFIG_PHY_DATA_OFFSET=0xf000
CONFIG_OPTIMIZATION_LEVEL_DEBUG=y
# CONFIG_OPTIMIZATION_LEVEL_RELEASE is not set
# Component config
CONFIG_BT_ENABLED=y
CONFIG_BTC_TASK_STACK_SIZE=3072
# CONFIG_BLUEDROID_MEM_DEBUG is not set
CONFIG_BT_RESERVE_DRAM=0x10000
# ESP32-specific
# CONFIG_ESP32_DEFAULT_CPU_FREQ_80 is not set
# CONFIG_ESP32_DEFAULT_CPU_FREQ_160 is not set
CONFIG_ESP32_DEFAULT_CPU_FREQ_240=y
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ=240
CONFIG_MEMMAP_SMP=y
# CONFIG_MEMMAP_TRACEMEM is not set
CONFIG_TRACEMEM_RESERVE_DRAM=0x0
# CONFIG_ESP32_ENABLE_COREDUMP_TO_FLASH is not set
# CONFIG_ESP32_ENABLE_COREDUMP_TO_UART is not set
CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE=y
# CONFIG_ESP32_ENABLE_COREDUMP is not set
CONFIG_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE=2048
CONFIG_MAIN_TASK_STACK_SIZE=4096
CONFIG_NEWLIB_STDOUT_ADDCR=y
# CONFIG_NEWLIB_NANO_FORMAT is not set
CONFIG_CONSOLE_UART_DEFAULT=y
# CONFIG_CONSOLE_UART_CUSTOM is not set
# CONFIG_CONSOLE_UART_NONE is not set
CONFIG_CONSOLE_UART_NUM=0
CONFIG_CONSOLE_UART_BAUDRATE=115200
# CONFIG_ULP_COPROC_ENABLED is not set
CONFIG_ULP_COPROC_RESERVE_MEM=0
# CONFIG_ESP32_PANIC_PRINT_HALT is not set
CONFIG_ESP32_PANIC_PRINT_REBOOT=y
# CONFIG_ESP32_PANIC_SILENT_REBOOT is not set
# CONFIG_ESP32_PANIC_GDBSTUB is not set
CONFIG_ESP32_DEBUG_OCDAWARE=y
CONFIG_INT_WDT=y
CONFIG_INT_WDT_TIMEOUT_MS=300
CONFIG_TASK_WDT=y
# CONFIG_TASK_WDT_PANIC is not set
CONFIG_TASK_WDT_TIMEOUT_S=5
CONFIG_TASK_WDT_CHECK_IDLE_TASK=y
# CONFIG_ESP32_TIME_SYSCALL_USE_RTC is not set
CONFIG_ESP32_TIME_SYSCALL_USE_RTC_FRC1=y
# CONFIG_ESP32_TIME_SYSCALL_USE_FRC1 is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_NONE is not set
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_RC=y
CONFIG_ESP32_DEEP_SLEEP_WAKEUP_DELAY=0
CONFIG_WIFI_ENABLED=y
# CONFIG_SW_COEXIST_ENABLE is not set
CONFIG_ESP32_WIFI_RX_BUFFER_NUM=25
CONFIG_PHY_ENABLED=y
# PHY
CONFIG_ESP32_PHY_AUTO_INIT=y
# CONFIG_ESP32_PHY_INIT_DATA_IN_PARTITION is not set
CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP32_PHY_MAX_TX_POWER=20
# CONFIG_ETHERNET is not set
# FreeRTOS
CONFIG_FREERTOS_UNICORE=y
CONFIG_FREERTOS_CORETIMER_0=y
# CONFIG_FREERTOS_CORETIMER_1 is not set
CONFIG_FREERTOS_HZ=1000
CONFIG_FREERTOS_ASSERT_ON_UNTESTED_FUNCTION=y
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_NONE is not set
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_PTRVAL=y
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY is not set
CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS=3
CONFIG_FREERTOS_ASSERT_FAIL_ABORT=y
# CONFIG_FREERTOS_ASSERT_FAIL_PRINT_CONTINUE is not set
# CONFIG_FREERTOS_ASSERT_DISABLE is not set
CONFIG_FREERTOS_BREAK_ON_SCHEDULER_START_JTAG=y
# CONFIG_ENABLE_MEMORY_DEBUG is not set
CONFIG_FREERTOS_ISR_STACKSIZE=1536
# CONFIG_FREERTOS_LEGACY_HOOKS is not set
# CONFIG_FREERTOS_DEBUG_INTERNALS is not set
# Log output
# CONFIG_LOG_DEFAULT_LEVEL_NONE is not set
# CONFIG_LOG_DEFAULT_LEVEL_ERROR is not set
# CONFIG_LOG_DEFAULT_LEVEL_WARN is not set
CONFIG_LOG_DEFAULT_LEVEL_INFO=y
# CONFIG_LOG_DEFAULT_LEVEL_DEBUG is not set
# CONFIG_LOG_DEFAULT_LEVEL_VERBOSE is not set
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_COLORS=y
# LWIP
# CONFIG_L2_TO_L3_COPY is not set
CONFIG_LWIP_MAX_SOCKETS=4
CONFIG_LWIP_THREAD_LOCAL_STORAGE_INDEX=0
# CONFIG_LWIP_SO_REUSE is not set
# CONFIG_LWIP_SO_RCVBUF is not set
CONFIG_LWIP_DHCP_MAX_NTP_SERVERS=1
# CONFIG_LWIP_IP_FRAG is not set
# CONFIG_LWIP_IP_REASSEMBLY is not set
CONFIG_TCP_MAXRTX=12
CONFIG_TCP_SYNMAXRTX=6
# CONFIG_LWIP_DHCP_DOES_ARP_CHECK is not set
# mbedTLS
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=16384
# CONFIG_MBEDTLS_DEBUG is not set
CONFIG_MBEDTLS_HARDWARE_AES=y
CONFIG_MBEDTLS_HARDWARE_MPI=y
CONFIG_MBEDTLS_MPI_USE_INTERRUPT=y
CONFIG_MBEDTLS_HARDWARE_SHA=y
CONFIG_MBEDTLS_HAVE_TIME=y
# CONFIG_MBEDTLS_HAVE_TIME_DATE is not set
# OpenSSL
# CONFIG_OPENSSL_DEBUG is not set
CONFIG_OPENSSL_ASSERT_DO_NOTHING=y
# CONFIG_OPENSSL_ASSERT_EXIT is not set
# SPI Flash driver
# CONFIG_SPI_FLASH_ENABLE_COUNTERS is not set
I use ESP32 download tool v3.4.4 and this is the screenshot of the program.
- Immagine.jpg (79.22 KiB) Viewed 20216 times
I changed the FLASH SIZE to 32Mbit and I use for partition_singleapp.bin the offset 0x4000 (with the other version I had to use 0x8000).
And it seems to work with the example which come from the esp-idf-template from github.
If I use my main.c file (compiled and working on former firmware release) I got this
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0x00
mode:DIO, clock div:2
load:0x3fff0008,len:8
load:0x3fff0010,len:2388
load:0x40078000,len:6788
load:0x40080000,len:252
entry 0x40080034
[0;32mI (836) heap_alloc_caps: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (836) heap_alloc_caps: At 3FFC7300 len 00018D00 (99 KiB): DRAM[0m
[0;32mI (845) heap_alloc_caps: At 3FFE8000 len 00018000 (96 KiB): D/IRAM[0m
[0;32mI (867) heap_alloc_caps: At 4009D6BC len 00002944 (10 KiB): IRAM[0m
[0;32mI (887) cpu_start: Pro cpu up.[0m
[0;32mI (899) cpu_start: Single core mode[0m
[0;32mI (911) cpu_start: Pro cpu start user code[0m
[0;32mI (1142) phy: phy_version: 258, Nov 29 2016, 15:51:07, 0, 0[0m
[0;32mI (1575) cpu_start: Starting scheduler on PRO CPU.[0m
Do you think it is ok?
