gpio_wakeup_disable has no impact, with test case
kuhatovuk
Postby kuhatovuk » Wed Mar 11, 2020 2:56 pm
Hello, any idea why gpio_wakeup_disable has no impact here ? ESP32 (IDF4) keeps on waking up if I put pin 25 to GND.
void app_main()
    gpio_set_pull_mode(GPIO_NUM_25, GPIO_PULLUP_ONLY);
    gpio_set_direction(GPIO_NUM_25, GPIO_MODE_INPUT);
    gpio_wakeup_enable(GPIO_NUM_25, GPIO_INTR_LOW_LEVEL);
    esp_sleep_enable_gpio_wakeup();
    esp_light_sleep_start();
    // Put pin 25 to GND
    ESP_LOGE("Test", "Wakes as expected");
    gpio_wakeup_disable(GPIO_NUM_25); // <---- has no impact
    while(1) {
        ESP_LOGE("Test", "Wakes but shouldn't");
Thank you!
kuhatovuk
Re: gpio_wakeup_disable has no impact, with test case
Postby kuhatovuk » Wed Mar 11, 2020 3:40 pm
It's a 4.0 bug where gpio enable calls the RTC function but not disable :
https://github.com/espressif/esp-idf/bl ... pio.c#L470
ESP_houwenxiang
Postby ESP_houwenxiang » Tue Mar 17, 2020 5:10 am
Hi, kuhatovuk
Thanks for reporting this issue. We will fix it soon.
wookooho
Users browsing this forum: Baidu [Spider], Google [Bot], MicroController, snutw_ and 108 guests
