ESP32 i2C support
yashdave88
ESP32 i2C support
Postby yashdave88 » Wed Feb 19, 2020 3:54 am
Problem statement: I am facing problem while reading registers over I2c, for CY8cmbr3116 cypress capsense controller.
Firmware details:
• ESP32 is configured as I2c master.
• Two devices are connected over I2c bus.
• Both are operating on 100Khz frequency.
ESP-IDF V3.3
I am using same i2c driver for port expander to read and write data over port.
I have verified slave address, for capsense controller and it is correct.
Could you please help me to resolve this.
ESP_houwenxiang
Re: ESP32 i2C support
Postby ESP_houwenxiang » Wed Feb 19, 2020 8:44 am
Hi, yashdave88
Can you provide more information about the I2C problem you are experiencing? Such as providing waveforms during communication.
thanks !!
wookooho
yashdave88
Postby yashdave88 » Thu Feb 20, 2020 5:13 am
Hi
Kindly find attached screenshot of signal. Also find attached code we are using.
i2c_example_main.c
(14.33 KiB) Downloaded 459 times
WiFive
Postby WiFive » Fri Feb 21, 2020 2:08 am
I am facing problem
We are supposed to guess? You have to show logs and error codes.
yashdave88
Postby yashdave88 » Tue Feb 25, 2020 8:34 am
HI,
We do not receive any error code
But our register read always fail.
Here with my logs
I (232) heap_init: Initializing. RAM available for dynamic allocation:
I (239) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (245) heap_init: At 3FFB2AA0 len 0002D560 (181 KiB): DRAM
I (252) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (258) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (264) heap_init: At 4008ADE4 len 0001521C (84 KiB): IRAM
I (271) cpu_start: Pro cpu start user code
I (288) spi_flash: detected chip: generic
I (289) spi_flash: flash io: dio
I (289) cpu_start: Starting scheduler on PRO CPU.
----Port expander init done----
----hardware reset init done----
----TASK[0] Task READ ----
f8 ff fd 3f 1f 51 6d fc d3 9c c2 f4 a9 d9 20 bc
ec 2f 23 9a
ec 2f 23 9a
ec 2f 23 9a
ec 2f 23 9a
ec 2f 23 9a
ec 2f 23 9a
ec 2f 23 9a
ec 2f 23 9a
ec 2f 23 9a
ec 2f 23 9a
ec 2f 23 9a
kindly suggest.
Postby ESP_Sprite » Thu Feb 27, 2020 9:52 am
How do you get that your register read always fails? From what I can see at a quick glance, that looks like mostly sane data to get from address 0xA0 in that chip.
yashdave88
Postby yashdave88 » Mon Mar 02, 2020 7:11 am
kindly find attached code we are using.
Also find below log according to this code.
I (190) cpu_start: Project name: i2c-example
I (196) cpu_start: App version: v4.1-dev-1543-g431066f16-dirty
I (203) cpu_start: Compile time: Mar 2 2020 10:54:56
I (209) cpu_start: ELF file SHA256: 2d45717555bc47dc...
I (215) cpu_start: ESP-IDF: v4.1-dev-1543-g431066f16-dirty
I (222) cpu_start: Starting app cpu, entry point is 0x40081074
0x40081074: call_start_cpu1 at C:/msys32/home/vishakhak/esp/esp-idf/components/esp32/cpu_start.c:276
I (0) cpu_start: App cpu up.
I (251) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (270) cpu_start: Pro cpu start user code
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00
00 00 00 00
00 00 00 00
00 00 00 00
00 00 00 00
00 00 00 00
00 00 00 00
Let me know any change require in code to get proper data.
i2c_example_main.c
(14.39 KiB) Downloaded 461 times
Postby ESP_Sprite » Tue Mar 03, 2020 2:03 pm
No, I'm not going to debug your code, especially if it's a hacked together example with remaining stuff commented out. Try some stuff yourself first: for instance, the I2C driver routines can return an error; how about actually checking if they do?
Users browsing this forum: No registered users and 91 guests
