ESP-IDF Tools unable to install
linearo
Postby linearo » Sun Nov 03, 2019 2:50 pm
Hi everyone,
if i try to install the ESP-IDF Tools, I get the error: "Failed to copy ESP-IDF to the destination directory: (Path)"
I am using Windows 10 on a 64 bit system.
I tried everything I can imagine e.g. changing Folder and partition or running with admin rights. Even on another Computer the same error occurred.
Internet research doesn't bring me a solution.
Thank you in advance!
linearo
Re: ESP-IDF Tools unable to install
Postby linearo » Wed Nov 13, 2019 3:22 pm
I was successful now.
I didn't change anything, but it worked in the 30th try....
Only thing that changed was, that I was in another WiFi. Don't know if that was the reason.
cspanza
Postby cspanza » Fri Dec 20, 2019 6:02 pm
I have the same problem, I ran the install as administrator and I even tried manually creating the target directory.
Here is the log.
2019-12-20 09:28:36.465 --------
2019-12-20 09:28:36.467 Moving C:\Users\Craig\AppData\Local\Temp\is-2AVGD.tmp\esp-idf-v3.3.1 to g:\Users\Craig\Desktop\esp-idf
2019-12-20 09:28:36.467 Message box (OK):
Failed to copy ESP-IDF to the destination directory: g:\Users\Craig\Desktop\esp-idf
2019-12-20 09:30:00.670 User chose OK.
2019-12-20 09:30:00.670 Message box (Yes/No):
Installation log has been created, it may contain more information about the problem.
Display the installation log now?
2019-12-20 09:30:03.035 User chose Yes.
2019-12-20 09:30:03.091 CurStepChanged raised an exception.
JacquesRoth
Postby JacquesRoth » Tue Feb 11, 2020 6:41 pm
I am having exactly the same problem. I do not have any spaces or dashes in my user name or any directory I entered during the installation, but I see dashes in things like ESP-IDF I have no control over. Doe anyone have a solution?
Error I get in the log is:
ESP_igrr
Postby ESP_igrr » Tue Feb 11, 2020 7:41 pm
Hi jacquesRoth,
Is your destination directory on a different drive? If yesz could you please try this version? https://github.com/espressif/esp-idf/is ... -584772989
Users browsing this forum: arex-ebee and 117 guests
