PWM Generating at expanded GPIO
Humam Helfawi
Postby Humam Helfawi » Fri Dec 06, 2019 1:06 pm
I have I2C GPIO expander. I used to generate PWM using
ledc_channel_config
ledc_set_duty
and
ledc_update_duty
at one of the original GPIOs of the ESP32.
Is it possible to use those function to generate PWM at GPIO in the expander? If not, what s the best way to do this manually? I tried to start new task
xCreateTask
and do the generating manually via sending LOW and HIGH signals to the external GPIO but it was very slow and killing the ESP processor (I need 5KHZ frequency PWM).
Any suggestion?
Thanks!
WiFive
Re: PWM Generating at expanded GPIO
Postby WiFive » Sat Dec 07, 2019 1:57 am
The best way is use an expander that has a built in led driver
Humam Helfawi
Postby Humam Helfawi » Sat Dec 07, 2019 11:09 am
Thanks for your reply! Do you have any suggestion?
Humam Helfawi
Postby Humam Helfawi » Sat Dec 07, 2019 11:20 am
I found this one http://www.ti.com/lit/an/snva287a/snva287a.pdf. but I think it is overkill (16 IOs). I am looking for at max 4 IOs only single one of them should have PWM ability.
Users browsing this forum: Majestic-12 [Bot] and 125 guests
