Reading temperature and humidity
drwill
Postby drwill » Fri Nov 08, 2019 12:55 am
I'm using an ESP32 Azure IoT Kit. I want to send temperature and humidity along as telemetry to my IoT hub.
I cannot find almost any information on how to do this. I came across one post here where someone refers to using uint8_t temprature_sens_read() (note that the word temperature is misspelled) and much to my surprise that worked. I've searched the code base in esp-idf and can't find a single file that defines that function. There is no include file, you just "extern" it in your .c file.
I still need to get humidity. I haven't found any documentation or samples about that.
Am I reading temperature the right way? How do I get humidity?
Thanks,
David
P.S. I'm surprised the temperature reading is in F. I'd think C would be a better worldwide standard, and I'm curious about the decision to report in F.
WiFive
Re: Reading temperature and humidity
Postby WiFive » Fri Nov 08, 2019 2:00 am
drwill
Postby drwill » Fri Nov 08, 2019 2:33 am
I found this sample, which uses a very different approach than the function I found for temperature earlier.
Is this what is recommended?
https://github.com/espressif/esp-iot-so ... ain/main.c
Thanks,
David
WiFive
Postby WiFive » Fri Nov 08, 2019 3:34 am
temprature_sens_read is not what you want. It is for reading esp32 internal temperature.
drwill
Postby drwill » Sat Nov 09, 2019 12:11 am
Gotcha.
In the samples, why are temp and humidity divided by 10?
WiFive
Postby WiFive » Sat Nov 09, 2019 1:07 am
To convert to decimal
drwill
Postby drwill » Sat Nov 09, 2019 1:30 am
I guess a better way to ask my question is, if my temperature reading is 30.4 C, why is it stored as 304?
I assumed the values are stored with accuracy of 0.1, but as an integer because maybe they store better than floats.
tommeyers
Postby tommeyers » Sat Nov 09, 2019 1:42 pm
Are you using the HTS221 temp/humid sensor ?
if so: https://github.com/espressif/esp-iot-so ... /README.md
IT Professional, Maker
Santiago, Dominican Republic
drwill
Postby drwill » Sat Nov 09, 2019 9:28 pm
I didn't realize I am, but I am. I took a second look at the spec sheet to confirm. I'm new to MCUs and honestly don't know many things, but I'm learning.
I got a solution working yesterday, but the instructions didn't work. I resorted to copying the relevant components to my project component directory, and it finally built.
tommeyers
Postby tommeyers » Sat Nov 09, 2019 10:25 pm
Post what you need.
Post what you have tried.
we'll help where we can.
Tom
Users browsing this forum: ESP_Sprite, Google [Bot] and 108 guests
