Shared code and cross-platform stubs in IDF CMake API v4.0
MindReader32
Postby MindReader32 » Thu Oct 10, 2019 7:33 am
I've built a project based on the idf_as_lib example project and want to take it further:
1. support shared code that can target both ESP32 and 'HOST', as it's not platform specific
2. allow the shared code to reside outside the source tree (i.e. $PROJECT_SOURCE_DIR/../shared/...)
3. in addition, some shared code in #1 may have ESP32 dependencies, but when compiling for HOST it should use 'stubs' (for testing)
I've gotten part way but have seem to hit a wall.
Using the IDF CMake API I was able to do #2 (until I tried to compile for HOST) and I'm not seeing a way todo #1
To resolve the issue with #2 for HOST it looks like I need to duplicate IDF CMake API and native CMake, e.g. in my testing $PROJECT_SOURCE_DIR/../shared/utils/CMakeLists.txt contains :
if("${TARGET}" STREQUAL "esp32")
    idf_component_register(INCLUDE_DIRS include)
else()
    add_library(shared_utils INTERFACE)
    target_include_directories(shared_utils INTERFACE .)
    add_library(shared::utils ALIAS shared_utils)
endif()
Which works for the ESP32 build but when I go todo the HOST build it looks like I'm going to have to go some way to create a 'HOST' based IDF CMakeAPI, or some such similar helpers, as CMake complains "specifying an out-of-tree source a binary directory must be explicitly specified"
I've not tackled #3 yet.
It's increasingly looking like I'm going to have to go 'native' CMake and re-implement/re-use parts of the IDF Make API in the process, something I wish to avoid.
Thanks in advance for any help!
MindReader32
Re: Shared code and cross-platform stubs in IDF CMake API v4.0
Postby MindReader32 » Sun Oct 13, 2019 9:24 am
I've waded thru this (nodding appropriately) "Compatibility between "normal CMake" and ESP-IDF": https://esp32.com/viewtopic.php?f=13&t=7535&start=30
In the process found this: https://github.com/PerMalmberg/IO-Card-G3
Which leads to this: https://github.com/PerMalmberg/Smooth
Which looks awesome on both a build setup and library front, thank you permal !
permal
Postby permal » Sun Oct 13, 2019 9:33 am
You're welcome :)
Looking forward to you feedback. Smooth isn't perfect but it has worked well for me. Just recently a few others have also started using it so welcome to the club I guess. ;)
Users browsing this forum: No registered users and 235 guests
