W (287) spi_flash: Detected size(4096k) larger than the size in the binary image
header(2048k). Using the size in the binary image header.
Default flash size configuration is 2 MByte which you need to change as per your flash size of hardware which you are using like 4 MByte or 16 MByte.raldone01 wrote: ↑Thu Jul 18, 2019 5:30 pmWhen the chip boots I receive the following warning:What does it mean?Code: Select all
W (287) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
Great. Thanks for update.
Users browsing this forum: No registered users and 148 guests
