esp_http_client_perform blocks the task
burkulesomesh43
Postby burkulesomesh43 » Fri Feb 22, 2019 8:00 am
Hello everyone,
I am using esp_http_client librairy to post data to server.
please refer following link, I am using same code given in link.
https://www.esp32.com/viewtopic.php?f=2&t=8102#p34049
I am stucked in this issue from very long time. not getting any solution or no response from forum for this issue.
I am using esp-idf v3.1.2 stable version, it does not include async mode in the librairy.
Please give me solution as early as possible.
Thanks,
somesh
Somesh Burkule
jitin17
Re: esp_http_client_perform blocks the task
Postby jitin17 » Fri Feb 22, 2019 12:36 pm
Hey, Did you face a similar issue with master branch, and can you send us the log with debug enabled?
burkulesomesh43
Postby burkulesomesh43 » Fri Jun 07, 2019 11:54 am
Actually the API used for post request is blocking API. I think there is only solution to use async.
Somesh Burkule
Users browsing this forum: No registered users and 186 guests
