ESP32 kills Asus Blue Cave Router
samsonch
Postby samsonch » Tue May 14, 2019 8:13 am
When we connected ESP32 with an Asus Blue Cave router, it (this ESP32 connection) simply killed the entire router. Any connection sessions of the other devices with this Blue Cave died. We tried the standard example code came with the SDK, same result. Even the Blue Cave was set to AP mode, same problem. I called Asus Customer Care, they could not help at all. After the router was killed, the log showed:
May 13 21:49:06 kernel: [ 332.230000] [cbm] { cbm_queue_flush : 3647 }out QOCC 0
May 13 21:49:06 kernel: [ 332.290000]
May 13 21:49:30 logserver[1327]: [0797264867] [_parse_log:1180]: wlan0: Fatal Error in file: “TsManagerRecipient.c”; Fatal Print: TS Manager Recipient Fatal
May 13 21:49:36 kernel: [ 362.230000] [cbm] { cbm_queue_flush : 3647 }out QOCC 0
May 13 21:49:36 kernel: [ 362.290000]
May 13 21:49:51 logserver[1327]: [0818252808] [_parse_log:1180]: wlan0: Fatal Error in file: “TsManagerRecipient.c”; Fatal Print: TS Manager Recipient Fatal
May 13 21:49:56 kernel: [ 382.250000] [cbm] { cbm_queue_flush : 3647 }out QOCC 0
Any idea?
Samson
Sergio
Re: ESP32 kills Asus Blue Cave Router
Postby Sergio » Sat May 18, 2019 7:19 am
I have exactly the same issue. I have tried with esp32 from another brands but same result so yes, it's a router problem. Do you have stock firmware?
samsonch
Postby samsonch » Mon May 27, 2019 10:57 am
Hello Sergio,
The firmware version of the Asus Blue Cave was 3.0.0.4.384.45708. That is the officially released version by Asus. I tried to contact Asus support, but helpless.
Samson
Sergio
Postby Sergio » Wed May 29, 2019 7:00 pm
Same to me, told me to reset router, set defaults... Nothing useful... and very frustrating... Another router works great
jaime018
Postby jaime018 » Thu Jun 27, 2019 1:17 am
I got a same error with my xaiomi smartmi fan 2s.
I tried to connect the fan at the Asus blue cave and i got a fatal error with my waln0.
Does anyone got any solution to fix it?
Sergio
Postby Sergio » Mon Sep 16, 2019 10:29 am
Hi Samsonch, any news with this? Thanks
xiehang
Postby xiehang » Wed Nov 27, 2019 12:44 pm
We have applied to purchase this AP and have started debugging this issue.
Can you give me more information?
such as:
Packet capture
Reproduction method
Recurrence probability
xiehang
Postby xiehang » Fri Nov 29, 2019 7:57 am
I purchased a asus blue cave router with firmware version is 3.0.0.4.384_32948
But I did not encounter the problem you described.
Can you guide me to reproduce the problem?
Besmir.likaj
Postby Besmir.likaj » Mon Dec 16, 2019 6:22 pm
I have the same issue. My problem is related to MYSA smart thermostat. As soon as I try to connect it to the router. It crashes the whole network. The network currently supports 23 IOT devices.
I can provide logs and so on.
My temporary solution is to use a range extender that connects to the blue cave that provides the internet connexion to the smart thermostat.
xiehang
Postby xiehang » Thu Dec 19, 2019 8:35 am
I think you need to find Asus official to solve this issue.
Users browsing this forum: gamename and 95 guests
