esp_bluedroid_disable never returns
adam_ohara
Postby adam_ohara » Thu Mar 07, 2019 5:29 pm
I am working a project that requires enabling the bluetooth module for a short period of time before disabling it again. Enabling the module works fine, but I am having less luck disabling it. It appears that esp_bluedroid_disable never returns. I am using the following code:
ESP_LOGI(TAG, "Disabling Bluetooth");
if(esp_bluedroid_get_status() == ESP_BLUEDROID_STATUS_ENABLED){
    esp_bluedroid_disable();
    while(esp_bluedroid_get_status() == ESP_BLUEDROID_STATUS_ENABLED);
esp_bluedroid_deinit();
while(esp_bluedroid_get_status() != ESP_BLUEDROID_STATUS_UNINITIALIZED);
Any help would be appreciated.
Edit:
I found the problem. I was trying to disable the bluetooth from within a bluetooth callback, so was getting some kind of deadlock. I triggered the disable code on the timer thread to work around this.
MightyMarcus
Re: esp_bluedroid_disable never returns
Postby MightyMarcus » Thu Jan 26, 2023 5:04 pm
This saved my day! Had the same issue and was stuck for hours.
Went through the hoops of creating a forum acccount here, just to say thank you! :)
Users browsing this forum: Baidu [Spider], dzungpv and 83 guests
