UART capture
cvargcal
UART capture
Postby cvargcal » Sun Nov 04, 2018 8:26 pm
Hi, I have this:
void uart1_task(void *pvParameters){
	 char character;
	 char tem;
	    //struct cmdBuf cmdBuffer;
	   	keyboard_command_t keyboardCmd;
	    //Install UART driver, and get the queue.
		esp_err_t ret = ESP_OK;
		const uart_config_t uart_config = {
			.baud_rate = 9600,
			.data_bits = UART_DATA_8_BITS,
			.parity = UART_PARITY_DISABLE,
			.stop_bits = UART_STOP_BITS_1,
			.flow_ctrl = UART_HW_FLOWCTRL_DISABLE
		//update UART config
		ret = uart_param_config(UART_NUM_1, &uart_config);
		if(ret != ESP_OK)
			//ESP_LOGE(EXT_UART_TAG,"external UART param config failed");
		//set IO pins
		ret = uart_set_pin(UART_NUM_1, TXD1_PIN, RXD1_PIN, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
		if(ret != ESP_OK)
			//ESP_LOGE(EXT_UART_TAG,"external UART set pin failed");
	    uart_driver_install(UART_NUM_1, UART_FIFO_LEN * 2, UART_FIFO_LEN * 2, 0, NULL, 0);
	    //ESP_LOGI(EXT_UART_TAG,"external UART processing task started");
	    //cmdBuffer.state=CMDSTATE_IDLE;
	    while(1){
	            uart_read_bytes(UART_NUM_1, (uint8_t*) &character, 1, portMAX_DELAY); // read single byte
	    			 ESP_LOGI(CONSOLE_UART_TAG,"Uart1: %x",character);
	    			UID_RFID[i++]=character;
	    			          if(i==5) {                         // 00-00-00-00-'cheksum'
	    			               if((UID_RFID[0] ^ UID_RFID[1] ^ UID_RFID[2] ^ UID_RFID[3] ^ UID_RFID[4]) == 0){  // Valido el ID
	    			                  //IDcard.Enbytes[0] = UID_RFID[3]; //4
	    			                  //IDcard.Enbytes[1] = UID_RFID[2]; //3
	    			                  //IDcard.Enbytes[2] = UID_RFID[1]; //2
	    			                  //IDcard.Enbytes[3] = UID_RFID[0]; //1
	    			                  i=0x00;                         // Reincio contador
	    			                  //isCard=1;                       // Tarjeta presente
	    			            	   ESP_LOGI(CONSOLE_UART_TAG,"Tag OK: %s",UID_RFID);
	    			               else
	    			               //isCard=0x00;                       // Tarjeta invalida
	    			              memset(UID_RFID,NULL,sizeof(UID_RFID));
How print the buffer as string? this not work
ESP_LOGI(CONSOLE_UART_TAG,"Tag OK: %x",UID_RFID[k]); if work.
I want capture every character for use this function:
// ******* ASCCI to KEYBOARD
uint16_t ToHidKeyboardScancode(char c){
      switch(c){
      // Hex
         case 'A':   return(0x04);
         case 'B':   return(0x05);
         case 'C':   return(0x06);
         case 'D':   return(0x07);
         case 'E':   return(0x08);
         case 'F':   return(0x09);
         case '1':   return(0x1E);
         case '2':   return(0x1F);
         case '3':   return(0x20);
         case '4':   return(0x21);
         case '5':   return(0x22);  //
         case '6':   return(0x23);  //
         case '7':   return(0x24);  //
         case '8':   return(0x25);  //
         case '9':   return(0x26);  //
         case '0':   return(0x27);
      //if ((c>='a') && (c<='z')) return (c-'a'+'A');
      return(0);
Users browsing this forum: ESP_Roland and 105 guests
