Flash encryption key when CODING_SCHEME 3/4 used
chefotm
Postby chefotm » Fri Aug 24, 2018 5:02 pm
Hey guys.
Have one question. I made successfully ESP32 safe boot + flash encryption work on devkit (ESP-WROOM-32). Now i tried to make it work on ESP32-WROWER. I wrote the keys as previously on devkit. The same with the fuses. But the HW bootloader still not found the software bootloader (flash read error , 1000). I compared the fuses with devkit and found that WROWER have set the CODING_SCHEME efuse to 0x01 (it means all the key register blocks are used in 3/4 encode mode). Can you recommend me, how to calculate the encryption key? Here are the fuses:
DEVKIT FUSES:
espefuse.py v2.3.1
Connecting.....
Security fuses:
FLASH_CRYPT_CNT        Flash encryption mode counter                     = 7 R/W (0x7)
FLASH_CRYPT_CONFIG     Flash encryption config (key tweak bits)          = 15 R/W (0xf)
CONSOLE_DEBUG_DISABLE  Disable ROM BASIC interpreter fallback            = 1 R/W (0x1)
ABS_DONE_0             secure boot enabled for bootloader                = 1 R/W (0x1)
ABS_DONE_1             secure boot abstract 1 locked                     = 0 R/W (0x0)
JTAG_DISABLE           Disable JTAG                                      = 1 R/W (0x1)
DISABLE_DL_ENCRYPT     Disable flash encryption in UART bootloader       = 1 R/W (0x1)
DISABLE_DL_DECRYPT     Disable flash decryption in UART bootloader       = 1 R/W (0x1)
DISABLE_DL_CACHE       Disable flash cache in UART bootloader            = 1 R/W (0x1)
BLK1                   Flash encryption key
  = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -/-
BLK2                   Secure boot key
BLK3                   Variable Block 3
  = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
Efuse fuses:
WR_DIS                 Efuse write disable mask                          = 384 R/W (0x180)
RD_DIS                 Efuse read disablemask                            = 3 R/W (0x3)
CODING_SCHEME          Efuse variable block length scheme                = 0 R/W (0x0)
KEY_STATUS             Usage of efuse block 3 (reserved)                 = 0 R/W (0x0)
Config fuses:
XPD_SDIO_FORCE         Ignore MTDI pin (GPIO12) for VDD_SDIO on reset    = 0 R/W (0x0)
XPD_SDIO_REG           If XPD_SDIO_FORCE, enable VDD_SDIO reg on reset   = 0 R/W (0x0)
XPD_SDIO_TIEH          If XPD_SDIO_FORCE & XPD_SDIO_REG, 1=3.3V 0=1.8V   = 0 R/W (0x0)
SPI_PAD_CONFIG_CLK     Override SD_CLK pad (GPIO6/SPICLK)                = 0 R/W (0x0)
SPI_PAD_CONFIG_Q       Override SD_DATA_0 pad (GPIO7/SPIQ)               = 0 R/W (0x0)
SPI_PAD_CONFIG_D       Override SD_DATA_1 pad (GPIO8/SPID)               = 0 R/W (0x0)
SPI_PAD_CONFIG_HD      Override SD_DATA_2 pad (GPIO9/SPIHD)              = 0 R/W (0x0)
SPI_PAD_CONFIG_CS0     Override SD_CMD pad (GPIO11/SPICS0)               = 0 R/W (0x0)
DISABLE_SDIO_HOST      Disable SDIO host                                 = 0 R/W (0x0)
Identity fuses:
MAC                    MAC Address
  = 30:ae:a4:08:99:78 (CRC b5 OK) R/W
CHIP_VER_REV1          Silicon Revision 1                                = 1 -/W (0x1)
CHIP_VERSION           Reserved for future chip versions                 = 0 -/W (0x0)
CHIP_PACKAGE           Chip package identifier                           = 0 -/W (0x0)
Calibration fuses:
BLK3_PART_RESERVE      BLOCK3 partially served for ADC calibration data  = 0 -/W (0x0)
ADC_VREF               Voltage reference calibration                     = 1100 -/W (0x0)
Flash voltage (VDD_SDIO) determined by GPIO12 on reset (High for 1.8V, Low/NC for 3.3V).
WROWER fuses:
espefuse.py v2.3.1
Connecting........_
Security fuses:
  = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 91 12 10 00 00 00 00 00 00 00 00 00 00 00 00 R/W
Efuse fuses:
CODING_SCHEME          Efuse variable block length scheme                = 1 R/W (0x1)
Config fuses:
Identity fuses:
MAC                    MAC Address
  = b4:e6:2d:c8:0a:6d (CRC 79 OK) R/W
CHIP_VERSION           Reserved for future chip versions                 = 2 -/W (0x2)
Calibration fuses:
BLK3_PART_RESERVE      BLOCK3 partially served for ADC calibration data  = 1 -/W (0x1)
ADC_VREF               Voltage reference calibration                     = 1072 -/W (0x14)
ADC1_TP_LOW            ADC1 150mV reading                                = 342 R/W (0x10)
ADC1_TP_HIGH           ADC1 850mV reading                                = 3409 R/W (0x24)
ADC2_TP_LOW            ADC2 150mV reading                                = 489 R/W (0x11)
ADC2_TP_HIGH           ADC2 850mV reading                                = 3482 R/W (0x13)
ESP_Angus
Re: Flash encryption key when CODING_SCHEME 3/4 used
Postby ESP_Angus » Fri Sep 14, 2018 1:53 am
Hi chefotm,
Sorry for the long delay in getting back to you. A small number of WROVER modules were produced with 3/4 Coding Scheme enabled, however they are no longer being produced with this coding scheme. We don't have support for Flash Encryption or Secure Boot with 3/4 Coding Scheme yet, but it is planned for IDF V3.2.
If you have a production quantity of modules with 3/4 Coding Scheme and you need to roll out flash encryption and secure boot on these then please PM me on the forum and we'll work something out.
Angus
Users browsing this forum: No registered users and 106 guests
