Heap corrupting when using xQueue
Re: Heap corrupting when using xQueue
IDF-Monitor can also help you decode addresses in stack traces, if you use it to access the console:
https://docs.espressif.com/projects/esp ... nitor.html
Or you can run xtensa-esp32-elf-addr2line manually (the command line to use is written at the above page.)
Based on the results of the experiments, I determined that damage to the heap causes any malloc() call inside the RTOS task. After that, the application's operation becomes unstable, and any access to the heap causes crash or inadequate behavior.
I found a description of thread-safe implementations, pvPortMalloc(), but in my IDF they are described as follows:
#define pvPortMalloc malloc
#define pvPortFree free
I think the problem is solved. I added a file named heap_3.c to the project, which was taken from the full release of FreeRTOS, and replaced the definitions in the portable.h.
It was:
Became:
It was:
#define vPortFree free
void *pvPortMalloc( size_t xWantedSize ); // In heap_3.c
void vPortFree( void *pv ); // In heap_3.c
That doesn't seem reasonable.
Why do you think so?
I did not find a clear explanation of why the dynamic allocation of memory inside the RTOS task can mess up the heap. Perhaps at this point the system switches to another task, and the heap allocation table is corrupted.
On freertos.org was about the same question, and there they advised using thread-safe memory functions. This solved my problem.
First of all: heap_3.c is not threadsafe in the ESP32 environment: any tasks on the 2nd core will continue running when vTaskSuspendAll is called. Secondly: this allocator is just a small wrapper around the existing malloc() code; the difference in calling process probably changes the timing on a race condition in your code in such a way that it happens to work in this case. Thirdly: the fact that the error occurs in a FreeRTOS function does not mean the FreeRTOS function caused the memory cporruption: it just crashes because it can't handle the *results* of that corruption.
My guess is that you have a race condition somewhere in your code that tends to corrupt your memory. I suggest you try to figure out what this is using the heap debugging functions. If you're okay with posting your code here, we can also take a look at it.
In fact, the project is already very large and quite confusing. In addition, comments in Russian)
However, I can give a link to my SVN so you can take a look. I will send it to you with a personal message.
Also I want to note that the error does not necessarily occur in the RTOS task. It can occur in any random place, but it manifests itself only if in the RTOS task in some way were caused by malloc/realloc/free.
In addition, all RTOS tasks, except one, were commented out. In the event that the malloc was called in, a crash occurred.
Yep, just browsed through it, unfortunately it is indeed to complicated to casually look for buffer overflows and I can't easily compile it in such a way that it doesn't break because it needs certain bits of hardware. (tried, but I can't get the error, instead I get a crash when entering 'help' on the console...)
Yes, it uses NVS to store some settings, and only today I found that if they are not there can be a drop. However, this does not seem to be an error with a heap damage.
I will try to fix this problem and make a fresh commit.
Maybe im wrong but your local variable event is used between xQueueSend and xQueueReceive.x-8973 wrote:I use xQueue to exchange messages between two RTOS tasks. I encountered a problem when using xQueue causes damage to dynamic memory, and sometimes kernel panic. The xQueueCreate(), xQueueSend() and xQueueReceive() functions are used in accordance with the documentation for the RTOS.
I determine the memory corruption by the appearance of graphical artifacts on the OLED, for which the framebuffer was created using the function malloc(). Sometimes a kernel panic occurs, indicating the file is multi-heap.c. I can show the console output when the kernel panic reoccurs.Code: Select all
void app_main() { ... systemEvtQueue = xQueueCreate(10, sizeof(uint8_t)); ... } static void task1(void *pvParameters) { uint8_t event = 0; while (1) { event = 3; xQueueSend(systemEvtQueue, (void *)&event, (TickType_t)0); ESP_LOGI(__func__, "Sending event %i", event); vTaskDelay(1000 / portTICK_PERIOD_MS); } } static void task2(void *pvParameters) { uint8_t event = 0; while (1) { if (xQueueReceive(systemEvtQueue, (void *)&event, (TickType_t)0)) { ESP_LOGI(__func__, "Received event %i", event); } vTaskDelay(100 / portTICK_PERIOD_MS); } }
Furthermore you create the queue by xQueueCreate(10, sizeof(uint8_t));
but you send and receive a "pointer".
Have you tried with xQueueCreate(10, sizeof(uint8_t*));
Users browsing this forum: Google [Bot] and 221 guests
