I'm trying to build and app that simply scans all available networks, and prints the details...
In the event handler, the wifi scan is started upon SYSTEM_EVENT_STA_START and then, upon SYSTEM_EVENT_SCAN_DONE a binary semaphore is given to a task.
Inside the task, esp_wifi_scan_get_ap_num() and esp_wifi_scan_get_ap_records() are called.
Ufortunately, app crashes with the following:
I noticed that app would not crash if all the functions are called from the event handler directly, or if I comment out esp_wifi_scan_get_ap_records() function inside the task!C:/msys32/home/Toni/esp/esp-idf/components/freertos/queue.c:1441 (xQueueGenericReceive)- assert failed!
abort() was called at PC 0x4008bfa0 on core 1
0x4008bfa0: xQueueGenericReceive at C:/msys32/home/Toni/esp/esp-idf/components/freertos/queue.c:2037
Backtrace: 0x4008d353:0x3ffd7ee0 0x4008d4ab:0x3ffd7f00 0x4008bfa0:0x3ffd7f20 0x400d244a:0x3ffd7f60
0x4008d353: invoke_abort at C:/msys32/home/Toni/esp/esp-idf/components/esp32/panic.c:649
0x4008d4ab: abort at C:/msys32/home/Toni/esp/esp-idf/components/esp32/panic.c:649
0x400d244a: app_task at C:/msys32/home/Toni/esp/wifi-scan-test/main/wifi-scan-test.c:57
I checked the line 1441 inside queue.c but I really don't understand how could I affect this from the app...
Please help.
Here is the code:
#include <stdio.h>
#include "esp_types.h"
#include "freertos/task.h"
#include "freertos/queue.h"
#include "soc/timer_group_struct.h"
#include "driver/periph_ctrl.h"
#include "driver/timer.h"
#include <esp_task_wdt.h>
#include <esp_log.h>
#include "freertos/semphr.h"
#include "esp_wifi.h"
#include "esp_event_loop.h"
#include "nvs_flash.h"
wifi_scan_config_t scan_config;
SemaphoreHandle_t scan_semaphore;
wifi_country_t country_config;
wifi_ap_record_t ap_records;
uint16_t num_of_scanned_aps;
esp_err_t event_handler(void *ctx, system_event_t *event)
int ev = event ->event_id;
switch(ev)
case SYSTEM_EVENT_STA_START:
ESP_LOGI("WIFI-SCAN-TEST", "SYSTEM_EVENT_STA_START");
ESP_ERROR_CHECK(esp_wifi_set_country(&country_config));
ESP_ERROR_CHECK(esp_wifi_scan_start(&scan_config, 0));
break;
case SYSTEM_EVENT_SCAN_DONE:
ESP_LOGI("WIFI-SCAN-TEST", "SYSTEM_EVENT_SCAN_DONE");
xSemaphoreGive(scan_semaphore);
break;
default:
ESP_LOGI("WIFI-SCAN-TEST", "Default event occured %d", ev);
break;
return ESP_OK;
void app_task(void* p)
while(1)
if(xSemaphoreTake(scan_semaphore, portMAX_DELAY) == pdTRUE)
ESP_LOGI("SEMAPHORE", "Semaphore taken");
ESP_ERROR_CHECK(esp_wifi_scan_get_ap_num(&num_of_scanned_aps));
ESP_LOGI("SCANNED", "APS number: %d", num_of_scanned_aps);
ESP_ERROR_CHECK(esp_wifi_scan_get_ap_records(&num_of_scanned_aps, &ap_records));
ESP_LOGI("SCANNED", "RSSI: %d", ap_records.rssi);
void app_main()
// Initialize NVS
esp_err_t ret = nvs_flash_init();
if (ret == ESP_ERR_NVS_NO_FREE_PAGES) {
ESP_ERROR_CHECK(nvs_flash_erase());
ESP_ERROR_CHECK(ret);
wifi_init_config_t wifi_init_config = WIFI_INIT_CONFIG_DEFAULT();
wifi_config_t wifi_config;
//wifi_config.sta.ssid = ;
//wifi_config.sta.password = ;
wifi_config.sta.scan_method = WIFI_ALL_CHANNEL_SCAN;
wifi_config.sta.bssid_set = 0;
//wifi_config.sta.bssid = ;
wifi_config.sta.channel = 0;
wifi_config.sta.sort_method = WIFI_CONNECT_AP_BY_SIGNAL;
wifi_config.sta.threshold.rssi = -127;
wifi_config.sta.threshold.authmode = WIFI_AUTH_OPEN;
//Wifi scan cnofig
scan_config.show_hidden = 1;
scan_config.scan_type = WIFI_SCAN_TYPE_ACTIVE;
scan_config.scan_time.active.min = 0;
scan_config.scan_time.active.max = 1500;
scan_config.channel = 0;
//Wifi country config
country_config.cc[0] = 'E';
country_config.cc[1] = 'U';
country_config.schan = 1;
country_config.nchan = 13;
country_config.policy = WIFI_COUNTRY_POLICY_AUTO;
//Initialize wifi
tcpip_adapter_init();
ESP_ERROR_CHECK(esp_event_loop_init(event_handler, NULL));
ESP_ERROR_CHECK(esp_wifi_init(&wifi_init_config));
//Create semaphore
scan_semaphore = xSemaphoreCreateBinary();
//Create app task
xTaskCreate(app_task, "app_task", 4000, NULL, 2, NULL);
//Set mode -> station
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
//Set config for station
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
