What does spi_device_interface_config_t.mode mean
peterlspot
Postby peterlspot » Sun Jun 03, 2018 9:07 am
I am wondering if there are any description about the .mode field in spi_device_interface_config_t structure?
Currently I can only find a simple comment line like "SPI mode (0-3) ", where can one find descriptions about the meaning for each value of "0, 1, 2, 3"?
I am wondering if the mode here means half-duplex or full-duplex, or anything else?
Below is what I can find from spi_master.c source code:
            if (dev->cfg.mode==0) {
                host->hw->pin.ck_idle_edge=0;
                host->hw->user.ck_out_edge=0;
                host->hw->ctrl2.miso_delay_mode=nodelay?0:2;
            } else if (dev->cfg.mode==1) {
                host->hw->user.ck_out_edge=1;
                host->hw->ctrl2.miso_delay_mode=nodelay?0:1;
            } else if (dev->cfg.mode==2) {
                host->hw->pin.ck_idle_edge=1;
            } else if (dev->cfg.mode==3) {
In my case, I am using 4 wire nCS, MISO, MOSI, SCLK to access a ADC module. I can read a single register byte using either mode 0 or 3.
Now I want read a batch of bytes from a starting register address, assuming their addresses are continuous. I am unsure if mode is related to this continuous read or not.
Regards,
peterlspot
peterlspot
Re: What does spi_device_interface_config_t.mode mean
Postby peterlspot » Sun Jul 01, 2018 12:42 am
Thank you WiFive!
Users browsing this forum: Google [Bot], Majestic-12 [Bot], nopnop2002 and 85 guests
