Dear all,
The new ESP-IDF which updated last week work this sample very well.
But, how much frequancy does the spi-slave reach? thanks.
大家好,
我的英文很差,请见谅。
官网上最新的sdk解决了这个问题。
我现在有个新问题请教各位大神,spi从端能达到的最高速度是多少?主端好像到几十M但是从端似乎跟不上
谢谢
SPI slave mode (example)
Re: SPI slave mode (example)
If you use random pins, the speed can go up to 20MHz (absolute max) if the signals are well-formed (50% duty cycle, clean edges etc) although a max of 10MHz may be better to keep in mind if you're not sure about the well-formed-ness. If you use the dedicated pins for the SPI peripheral you select, you can get up to 40MHz (again, absolute max) with well-formed signals and 20MHz for random signals.
Hi! ESP_Sprite,
Thanks for your reply.
I used the spi-slave sample upon two esp32-kit.
When I raise the sender's speed(ex. .clock_speed_hz=10000000), I receive messy message.
When I reduce the speed to 8MHz(.clock_speed_hz=8000000), it work well.
What's wrong with the spi-slave? Thank you!
我有两个esp32的开发板用于sdk里spi-slave的测试,
当我把发送端速度调到10M( .clock_speed_hz=10000000),收到的都是乱码;
当我把发送端速度调到8M(.clock_speed_hz=8000000),接受正常
spi的从端是否真能达到以上所说的20MHz(甚至是40MHz)?
Hard to say from wording like 'very messy'. Can you be more specific; what exactly do you send, what exactly do you receive? Do you have an oscilloscope trace of the signals on the line?
Hello!ESP_Sprite,
When I set .clock_speed_hz=8000000, the spi work well. But, when I set .clock_speed_hz=10000000, I receive wrong data as follow. Thanks!
Any chance you can connect an oscilloscope to your signal lines? I'm thinking that stray capacitance or something may mess up your clock signal.
LakshmiDhanaraj wrote:Hi,
I am using the SPI slaver driver example,sender as master and receiver as slave.I can able to transmit/receive data without dma.But it restricts the number of bytes to 32.For transmitting more than 32bytes,I am enabling the dma to 1,won't receive/transmits the data.Please help me out to solve this issue.What I have to change in the code for transmitting more than 32 bytes?
Can you please send the code, I am struggling with code.
Has anyone been able to send more than 32 bytes?
I would like to send 20,000 bytes but not sure if it is possible as I was limited to 32 bytes using the spi slave library.
Users browsing this forum: No registered users and 113 guests
