printf() requires a \n for output?
aekalman
Postby aekalman » Fri Oct 27, 2017 10:41 pm
Hello. This is my first post.
I am able to successfully build and run the hello_world application on a SparkFun ESP32 Thing module (26MHz main xtal).
However, I observer that whereas these lines in the example:
    for (int i = 10; i >= 0; i--) {
        printf("Restarting in %d seconds...\n", i);
work correctly, these altered lines do not output the "." character:
    int i=10;
    printf("Restarting in %d seconds \n", i);
    for (; i >= 0; i--) {
        printf(".");
but these do (but are not in the format that I want):
    int i=10;
        printf(".\n");
IOW, it appears that a call to printf() does not result in output to the terminal until a \n is injected into printf()'s arguments.
Based on my previous experience with printf() on embedded systems, this is not normal behavior. Is this intentional? Is there some option I need to set to ensure that whatever I send via printf() is output to the terminal, without requiring a \n?
Thanks,
ESP_igrr
Re: printf() requires a \n for output?
Postby ESP_igrr » Sun Oct 29, 2017 6:34 am
By default, output streams have line buffering enabled.
You can configure buffering for any particular stream using setvbuf function.
More info:
http://en.cppreference.com/w/c/io/setvbuf
https://github.com/espressif/newlib-esp ... vbuf.c#L20
For example,
setvbuf(stdout, NULL, _IONBF, 0);
disables buffering on stdout.
Note that you will generally get better performance if buffering is used. You can also use fflush(stdout) to flush the buffer without sending a newline.
aekalman
Postby aekalman » Fri Nov 03, 2017 9:18 pm
Thank you -- I suspected something like that, but didn't know where to look.
Thanks again,
Users browsing this forum: Google [Bot] and 100 guests
