RMT led encoder - Modify bytes on the fly
Xylopyrographer
Postby Xylopyrographer » Wed Jan 22, 2025 7:05 pm
Hi all. I'm working on some code based on the RMT Transmit Example -- LED Strip located here: https://github.com/espressif/esp-idf/tr ... /led_strip
I need to modify led_strip_encoder.c so that I can modify on the fly the byte pulled from the led_strip_pixels buffer before it is encoded and then sent further down the processing chain.
Need to do it this way so the bytes in the led_strip_pixels buffer remain as-is as the modification prior to encoding is destructive to the original byte value.
I don't have enough C or C++ knowledge to understand where in the led_strip_encoder.c code the byte is pulled from the buffer so if anyone can lend a hand would be very appreciated.
MicroController
Re: RMT led encoder - Modify bytes on the fly
Postby MicroController » Wed Jan 22, 2025 9:29 pm
Check out this example.
Xylopyrographer
Postby Xylopyrographer » Fri Jan 24, 2025 6:39 am
Thanks for the reply.
Yes, I did check out the simple encoder though it seems that with that, options like DMA, setting the GPIO pin as open drain, etc. cannot be used as it doesn't take a user defined `rmt_tx_channel_config_t` structure. Mind, I can't find where a default structure (if any) is defined so...
Postby ESP_Sprite » Sat Jan 25, 2025 3:06 am
It does. You still need to initialize the TX channel first before attaching a simple encoder, and that happens with rmt_new_tx_channel() which takes the usual config struct.
Xylopyrographer
Postby Xylopyrographer » Sat Jan 25, 2025 5:02 am
Well all righty then! I will certainly give that a shot. Very much appreciated.
Xylopyrographer
Postby Xylopyrographer » Tue Jan 28, 2025 5:06 am
Edit:
Got it figured!
Short answer; the complete definition of the callback configuration structure is:
typedef struct {
    rmt_encode_simple_cb_t callback;  /*!< Callback to call for encoding data into RMT items */
    void *arg;                        /*!< Opaque user-supplied argument for callback */
    size_t min_chunk_size;            /*!< Minimum amount of free space, in RMT symbols, the
                                           encoder needs in order to guarantee it always
                                           returns non-zero. Defaults
                                           to 64 if zero / not given. */
} rmt_simple_encoder_config_t;
So in the example, modify this structure to read:
    const rmt_simple_encoder_config_t simple_encoder_cfg = {
        encoder_callback,
        &brightness
        //Note we don't set min_chunk_size here as the default of 64 is good enough.
And lo and behold it all works with
`uint8_t brightness = 0;`
and the callback_encoder modified to:
    uint8_t photons = *( uint8_t* )arg; // Cast arg to uint8_t* and dereference to get the brightness value
    if ( data_pos < data_size ) {
        // Encode a byte
        // uint8_t currentByte = scale8( data_bytes[ data_pos ], brightness );
        // uint8_t currentByte = data_bytes[ data_pos ];
        // currentByte = scale8_video( currentByte, brightness );
        uint8_t currentByte = scale8_video( data_bytes[ data_pos ], photons );
Yippe-ki-a! :D
I've figured out a way to modify the data on the fly.
By declaring a global variable `brightness`, and changing the encoder_callback function, I can do (portion of the encoder callback function here):
        // Encode a byte
        uint8_t currentByte = scale8_video( data_bytes[ data_pos ], brightness );
        size_t symbol_pos = 0;
        for ( int bitmask = 0x80; bitmask != 0; bitmask >>= 1 ) {
            symbols[ symbol_pos++ ] = ( currentByte & bitmask ) ? ws2812_one : ws2812_zero;
        // We're done; we should have written 8 symbols.
        return symbol_pos;
which works fine (`scale8_video()` modifies the byte without affecting the original data).
Now the callback function is declared as:
static size_t encoder_callback( const void* data, size_t data_size,
                                size_t symbols_written, size_t symbols_free,
                                rmt_symbol_word_t* symbols, bool *done, void* arg )
and the last argument `void* arg` is an opaque pointer to arguments that can be used inside `encoder_callback()`.
However, I cannot figure out the syntax to make this happen -- that is pass the value of `brightness` into `encoder_callback() as an argument.
With `brightness`declared as a global as
and declaring:
`void* arg = &brightness;`
and then modifying the above code snippet to:
        // Encode a byte
        return symbol_pos;
The machine crashes as soon as the call to send the buffer to the LED's is called.
Any help on figuring this out would be very greatly appreciated.
Users browsing this forum: No registered users and 128 guests
