esp-tls: couldn't get hostname for :example.com: getaddrinfo() returns 202, addrinfo=0x0
JonasL
Postby JonasL » Wed Mar 29, 2023 11:09 am
Hello everyone,
I have stumbled upon a problem in the last step of my esp32 project with this error. This error occurs when I am calling esp_http_client_perform(client) API. ESP-IDF monitor provides the following message:
E (36765) esp-tls: couldn't get hostname for :example.com: getaddrinfo() returns 202, addrinfo=0x0
E (36765) esp-tls: Failed to open new connection
E (36775) transport_base: Failed to open a new connection
E (36775) HTTP_CLIENT: Connection failed, sock < 0
E (36785) HTTP event handler: HTTP_EVENT_ERROR
E (36785) HTTP client: HTTP POST request failed: ESP_ERR_HTTP_CONNECT
What I have noticed is that this error only occurs when esp32 connects to mobile wifi hotspot. When using home wifi connection http sequence goes without any errors. I have tried disabling ESP-TLS component in menuconfig, allowing potentially insecure options and skipping server verification. Similar error was discussed in these threads, not sure if error culprit is the same: https://esp32.com/viewtopic.php?t=26498
https://github.com/espressif/esp-idf/issues/6940
rahulbari
Re: esp-tls: couldn't get hostname for :example.com: getaddrinfo() returns 202, addrinfo=0x0
Postby rahulbari » Tue Jul 02, 2024 2:42 pm
I am facing the same issue, could you get any solution so that it would be helpful for us.
Thanks in advance
Rahul B.
esp32dev1
Postby esp32dev1 » Fri Jul 12, 2024 6:39 am
same issue
toljatyr
Postby toljatyr » Thu Nov 14, 2024 11:50 am
I am also facing the same. Error occurred and lasts for some time, but if I restart the MCU it works OK
chegewara
Postby chegewara » Wed Nov 20, 2024 6:48 am
There is not enough data to help with the issue.
Is the connection success before you call "getaddrinfo"? And by success, i mean you get IP address from DNS or set static IP after connecting to router.
Users browsing this forum: No registered users and 319 guests
