wifi message on connection
Gaston1980
Postby Gaston1980 » Mon Nov 11, 2024 10:42 pm
I was able to connect to wifi router but every time I got this message on terminal:
wifi:[ADDBA]RX DELBA, reason:39, delete tid:0, initiator:0(recipient)
It seems that the esp32 disconnect from router and ask for new IP address. This is the code I use to connect to wifi:
    esp_netif_init();                    // TCP/IP initiation 					s1.1
    esp_event_loop_create_default();     // event loop 			                s1.2
    my_staif = esp_netif_create_default_wifi_sta(); // WiFi station 	                    s1.3
    wifi_init_config_t wifi_initiation = WIFI_INIT_CONFIG_DEFAULT();
    esp_wifi_init(&wifi_initiation); // 					                    s1.4
    // 2 - Wi-Fi Configuration Phase
    esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, wifi_event_handler, NULL);
    esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, wifi_event_handler, NULL);
    wifi_config_t wifi_configuration = {
        .sta = {
            .ssid = "",
            .password =""
    strcpy((char*)wifi_configuration.sta.ssid,SSID);
    strcpy((char*)wifi_configuration.sta.password,PASS);
    esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_configuration);
    // 3 - Wi-Fi Start Phase
    esp_wifi_start();
    esp_wifi_set_mode(WIFI_MODE_STA);
    // 4- Wi-Fi Connect Phase
    esp_wifi_connect();
How do I solve this?
Regards
Gastón
Gaston1980
Re: wifi message on connection
Postby Gaston1980 » Wed Nov 13, 2024 12:46 pm
Hi, I tried to run the client example and when the example finish I got this too
How to know if this is something related to the router?
Regards
Gastón
chegewara
Postby chegewara » Wed Nov 20, 2024 6:40 am
Users browsing this forum: Baidu [Spider], markkuk and 291 guests
