I'm working on flash encryption for alot of time.
First i just used esptool and a blog about flash encryption from medium. In that blog they only asked me to burn flash_crypt_cnt and flash_crypt_config. This solved the purpose for me and i wasnt able to read the flash using esptool read flash function. So it was all good.
Later i started deep diving into flash encryption using esp-idf.
I got to know about two modes, development and release mode and was able to perform encryption.
I use uart to flash esp32 and will need it even after enabling flash encryption to reflash encrypted firmware unlimited times.
Im having some doubts:
1)What does disable_dl_encrypt and disable_dl_decrypt does?
- according to me disable_dl_encrypt=false help me to flash plaintext using espidf which gets encrypted everytime. Also when it is false and i flash unencrypted firmware using esptool, it gives me invalid header error but if i flash encrypted firmware using esptool it works alright. Why is that do? Why cant i flash plaintext via esptool?
- when performing encryption via espidf, it automatically make disable_dl_decrypt=true. But i have seen that the functioning is still same if if value is true or false. Like im still not able to read the flash using esptool read flash function.
So what actually is it?
2) what is flash_crypt_config? If i set value of it as 0xf it means esp32 will apply this config to encrypt the plaintext. But when i use esptool to encrypt plaintext and then flash the encrypted firmware on flash it works! Does esptool encrypt data function also assume config value as 0xf and encrypt accordingly?
Help with flash encryption
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- 全国大学生物联网设计竞赛乐鑫答疑专区
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: Bing [Bot] and 73 guests
- All times are UTC
- Top
- Delete cookies
About Us
