Hi I try to cnifgure for my board the external psram 8MB of my wrrom n16r8 but even if the ram if detected, there is a config issue:
As i have 8MB here, i selected Octal Mode, and it select by default pin30 and 26 for sck and cs, pin that are normally used on my pcb, but i removed the component to be sure for the test.
But as the help mention that it is possible to use any unused gpio, I changed to gpio41 and 42 that are left open, but it seems that range in kconfig for this value are 0-33, so in sdkconfig, my modifications seems to not be effective, and i still see the 30 and 26 value:
How to you do for this wroom kit please ?
Thank you
PSRAM octal menuconfig pin value
- 06d97d2067ff72049ae58b1881e0a3db9e8a781d.png (20.47 KiB) Viewed 555 times
- 2f84859b024d3d207aed061385d25d9c9a2bec29.png (17.17 KiB) Viewed 555 times
Re: PSRAM octal menuconfig pin value
Are you trying to change the wiring of the PSRAM on the N16R8 module via software?!
Hehe no,
I'm using esp32s3 wroom1 n16r8 module so...
But i thought it was possible to change the three pins 36 37 38 .
I'm a bit mixing all the informations in my head i will delete the post because you are right i was mixing informations in my head
Users browsing this forum: No registered users and 129 guests
