Where is Path specified??????????
klaatu2
Postby klaatu2 » Mon Aug 26, 2024 5:35 pm
Trying to compile example code
  Directory specified in EXTRA_COMPONENT_DIRS doesn't exist: E:/components
The path is wrong, where/how is it set?
floitsch_toit
Re: Where is Path specified??????????
Postby floitsch_toit » Tue Aug 27, 2024 11:57 am
https://docs.espressif.com/projects/esp ... le-project
Alternatively, EXTRA_COMPONENT_DIRS can be set in the top-level CMakeLists.txt to look for components in other places.
klaatu2
Postby klaatu2 » Tue Aug 27, 2024 4:56 pm
The CMakeLists.txt file has the following
# The following lines of boilerplate have to be in your project's
# CMakeLists in this exact order for cmake to work correctly
cmake_minimum_required(VERSION 3.5)
include($ENV{IDF_PATH}/tools/cmake/project.cmake)
set(EXTRA_COMPONENT_DIRS
    ../../components   (Was this the line that was the issue?)
add_compile_options(-fdiagnostics-color=always
                    -Wno-format
                    -DLV_LVGL_H_INCLUDE_SIMPLE
                    -Wno-ignored-qualifiers
                    -Wno-unused-function
                    -Wno-unused-variable)
project(smart_panel)
In the end, I just made sure I had the same directory structure as the example and got it to work. What was confusing, was this example had its own folder, but it was drawing from files outside/above the folder apparently files common to all examples. Never found any reference to the path to the files outside the example folder, other than "../../components" above
Users browsing this forum: No registered users and 99 guests
