I get an error when I compile for the ESP32-C6 chip the same code works for the ESP32-S3. Is it a known problem? here is the error: C:/Espressif/frameworks/esp-idf-v5.2.1/examples/Brainwave/ESP32C6_Test_LED_BLE_nimble/main/main.c:8:10: fatal error: esp_nimble_hci.h: No such file or directory
8 | #include "esp_nimble_hci.h"
compilation terminated.
Missing "esp_nimble_hci.h" file name found in the following component(s): bt(C:\Espressif\frameworks\esp-idf-v5.2.1\components\bt\host\nimble\esp-hci\include\esp_nimble_hci.h). Maybe one of the components needs to add the missing header directory to INCLUDE_DIRS of idf_component_register call in CMakeLists.txt.
ninja failed with exit code 1, output of the command is in the C:\Espressif\frameworks\esp-idf-v5.2.1\examples\Brainwave\ESP32C6_Test_LED_BLE_nimble\build\log\idf_py_stderr_output_10288 and C:\Espressif\frameworks\esp-idf-v5.2.1\examples\Brainwave\ESP32C6_Test_LED_BLE_nimble\build\log\idf_py_stdout_output_10288
I have added the main.c and the CMakeLists.txt
I have activated the Nimble BLE via idf.py Menuconfig.
To test with ESP32 S3 I did:
set IDF_TARGET=esp32s3
idf.py set-target esp32s3
Then it compiles without an error.
Change to ESP32-C6:
set IDF_TARGET=esp32c6
idf.py set-target esp32c6
The error above apears: esp_nimble_hci.h: No such file or directory
How can I solve the problem or is the ESP32-C6 not supporting nimble?
ESP32-C6 nimble not working same code works ith ESP32-S3
- main.c
- (2.95 KiB) Downloaded 34 times
- CMakeLists.txt
- (108 Bytes) Downloaded 26 times
Re: ESP32-C6 nimble not working same code works ith ESP32-S3
Do you have nimble enabled in the menuconfig? Iirc changing targets resets that to defaults.
I found the solution when I comment out this line:
//esp_nimble_hci_init();
Now it works.
Now it works.
Users browsing this forum: No registered users and 69 guests
