Modbus RTU problem with de signal
luk_ab
Postby luk_ab » Sat May 25, 2024 8:54 am
I'm using the modbus master example, since I'm having problems with the communication of my device I examined the signals on the TX RX and DE pins. Below you can see that the EN signal goes low before TX finishes transmitting.
logic
How can I fix this? Modbus speed 9600 TX - GPIO23 RX - GPIO22 DE - GPIO18
ESP_alisitsyn
Contact:
Re: Modbus RTU problem with de signal
Postby ESP_alisitsyn » Mon May 27, 2024 9:14 am
Hi @luk_ab,
Which version of esp-idf you are using? The issue you describe looks as already resolved issue with the UART driver in RS485 mode.
luk_ab
Postby luk_ab » Mon May 27, 2024 5:14 pm
Hi @ESP_alisytsyn in this project I am using ESP-IDF v5.1.2 communication I run on UART 2. I momentarily coped by using a separate task to control the DE pin. From which version of IDF does this work correctly?
ESP_alisitsyn
Contact:
Postby ESP_alisitsyn » Fri Jul 19, 2024 8:10 am
Hi @luk_ab,
Sorry for the late response.
As per my information the issue is fixed by commit https://github.com/espressif/esp-idf/co ... 9338ccdf37
Users browsing this forum: full_spectrum and 96 guests
