Can't set max Wi-Fi Power strength
thecashit
Postby thecashit » Sun Aug 27, 2017 5:55 am
Hello!
I need to reduce wifi signal strength to meet project requirements.
According to documentation - i tried to set it in sdkconfig to 6 dbm.
To check if it works i tried to measure it by Android phone in 5 metres distance.
But there no differences in 2 versions of firmware (6dbm and 20dbm). Absolutely no differencies.
I also tried to set 1dbm and the phone displays the same value as 6dbm and 20dbm.
Nevertheless, if I change the signal strength on the local Wifi Hotspot it changes and on the phone. So, the measurement seems to be correct.
As i set it in make menuconfig you can see in the eclosure.
ESP-IDF v3-dev
How to correct set WiFi power maximum?
I will be greatful for any help!
Снимок экрана 2017-08-27 в 10.52.54.png (83.06 KiB) Viewed 3369 times
Users browsing this forum: Bing [Bot] and 143 guests
