Smart config not working with android app
mh-dev
Postby mh-dev » Sat Jan 21, 2017 3:35 pm
I was able to get smart config on my esp32 running (at least as far as I can tell), but I am unable to transmit the AP name/pw via the android app. I expect this is related to the smart config version '2.6.3' in the SDK and the last update for the android app is '2.4'. The problem is that I can't find any documentation of the communication protocol. Should the app be working and I am doing something wrong. Or is there somewhere a documentation for the protocol?
ESP Log:
I (2705) wifi: frc2_timer_task_hdl:3ffbc828, prio:22, stack:2048
I (2705) wifi: Init lldesc rx mblock:25
I (2705) wifi: Init lldesc rx ampdu len mblock:7
I (2705) wifi: Init lldesc rx ampdu entry mblock:4
I (2715) wifi: pp_task_hdl : 3ffc96e0, prio:23, stack:8192
I (2715) wifi: mode : sta (24:0a:c4:03:02:bc)
I (3225) smartconfig: SC version: V2.6.3
I (7435) wifi: ic_enable_sniffer
End the status is in 'SC_STATUS_FIND_CHANNEL'
xzwang
Re: Smart config not working with android app
Postby xzwang » Thu Feb 09, 2017 2:14 am
I also get this problem, does anyone can give some suggestion?
mh-dev
Postby mh-dev » Thu Feb 09, 2017 5:32 am
I stopped considering smart config for now as an option.
I did later on a test where I used my phone as an access point and was able to perform smart config.
It seems like that my normal AP is blocking it or something like this.
only1chi
Postby only1chi » Mon May 22, 2017 2:41 pm
Did you later figure out why smartconfig was not working for you?
I'm running into the exact problems you had.
only1chi
Postby only1chi » Mon May 22, 2017 3:16 pm
Has anyone solved this problem with smartconfig using ESP Touch?
yxdhde
Postby yxdhde » Tue Aug 08, 2017 6:33 am
Same as mh-dev .
Users browsing this forum: Bing [Bot], michcfr, walkabout and 96 guests
