IDF 5.1+ and the new RMT API - loop count is not supported
technosf
Postby technosf » Thu Dec 28, 2023 8:53 pm
Hullo!
I am trying to transmit a uint32_t multiple times via the RMT peripheral using the byte encoder.
Duplicating the uint32_t into an array and sending the array works fine, but if I try to have the RMT peripheral itself loop over the single value by changing the rmt_transmit_config_t.loop_count to anything other than 0, I get this error:
rmt: rmt_transmit(478): loop count is not supported
Would someone know if this a setting in sdkconfig I need to change, a restriction on the esp32 chip, or does it just not work at this point?
Thanks!
technosf
[Solved] Re: IDF 5.1+ and the new RMT API - loop count is not supported
Postby technosf » Thu Dec 28, 2023 9:04 pm
To answer my own question, in soc_caps.h there is SOC_RMT_SUPPORT_TX_LOOP_COUNT which needs to be checked if you wish to do loops. From the rmt_tx code:
#if !SOC_RMT_SUPPORT_TX_LOOP_COUNT
    ESP_RETURN_ON_FALSE(config->loop_count <= 0, ESP_ERR_NOT_SUPPORTED, TAG, "loop count is not supported");
#endif // !SOC_RMT_SUPPORT_TX_LOOP_COUNT
Users browsing this forum: MicroController and 145 guests
