UPD Send frames Crash
tezaman
Postby tezaman » Thu Nov 23, 2023 3:37 pm
Hi hello there
Scenario
STM8266
FREE RTOS SDK
>>>>>Connecting to Mobile phone Wifi HotSpot
I am sending UDP Messages to a mobile app around 90 per second, inside a task , with a while(1)
the problem is that the code crash on me randomly , the less vTaskdelay i use the more is crashing.
The connection between ESP and phone is Solid and very close together
ERROR
91 Per Second
91 Per Second
91 Per Second
91 Per Second
91 Per Second
83 Per Second
24 Per Second
[0;31mE (454685) wifi: no buf for probe, ie len 0[0m
4 Per Second
5 Per Second
5 Per Second
4 Per Second
5 Per Second
pm 1253
 ets Jan  8 2013,rst cause:4, boot mode:(3,7)
wdt reset
abort() was called at PC 0x402518cb on core 0
Guru Meditation Error: Core  0 panic'ed (StoreProhibited). Exception was unhandled.
Core 0 register dump:
PC      : 0x402151b2  PS      : 0x00000033  A0      : 0x402151b0  A1      : 0x3fff9e20
A2      : 0x00000000  A3      : 0x00000001  A4      : 0xffffffdb  A5      : 0x00000001
A6      : 0x00000000  A7      : 0x00000000  A8      : 0x00000000  A9      : 0xffffffe3
A10     : 0x00000010  A11     : 0xfffffffc  A12     : 0x401074b0  A13     : 0x00000004
A14     : 0x40106f60  A15     : 0x40107314  SAR     : 0x0000001e  EXCCAUSE: 0x0000001d
Backtrace: 0x402151b2:0x3fff9e20 0x402518ce:0x3fff9e30 0x40251a41:0x3fff9e40 0x4027d1f3:0x3fff9e50 0x4027d254:0x3fff9e70 0x4027d2fe:0x3fff9ea0 0x40219792:0x3fff9eb0 0x40219fa5:0x3fff9f40 0x4021a102:0x3fff9f50 0x4021a5d5:0x3fff9f60 0x4021a90a:0x3fff9f70
CODE
inside TASK
			int sock = socket(addr_family, SOCK_DGRAM, ip_protocol);
            if (sock < 0)
                printf("Unable to create socket: errno %d", errno);
                printf("Failed to create socket/n");
                break;
            // Set timeout
            struct timeval timeout;
            timeout.tv_sec = 0;
            timeout.tv_usec = 0;
            setsockopt(sock, SOL_SOCKET, SO_RCVTIMEO, &timeout, sizeof timeout);
            printf("Socket created, sending to %s:%d", SERVER_IP, SERVER_PORT);
             while (1)
                const uint32_t cur_time = MY_MILLIS();
                    makedata();
                    if (elapsed_time(cur_time, send_time2) >= 1000)
                        send_time2 = cur_time;
                        printf("%d Per Second \n", countUDP);
                        countUDP = 0;
                    clientAddress.sin_family = AF_INET;
                    clientAddress.sin_port = htons(11000);
                    int sent3 = sendto(sock, (uint8_t *)data, sizeof(data), 0, (struct sockaddr *)&data, sizeof(clientAddress));
                    countUDP = countUDP + 1;
                    if (sent3 < 0)
                        printf(" send error number %d  from  Port %d %s \n", sent3, ntohs(clientAddress.sin_port), inet_ntoa(clientAddress.sin_addr));
                    if (elapsed_time(cur_time, send_time3) >= 20000)
                        send_time3 = cur_time;
                        sta_ip = wifi_got_ip();
                        ap_sta = wifi_ap_has_client();
                        connected = sta_ip || ap_sta;
                        printf("Check if is connected \n");
                vTaskDelay(10);   //the more the better but costs me frames....
MicroController
Re: UPD Send frames Crash
Postby MicroController » Thu Nov 23, 2023 9:41 pm
tezaman
Postby tezaman » Fri Nov 24, 2023 7:10 am
thanks
Interesting , i dont have this file xtensa-esp32-elf-addr2line.exe
i am using this version of xtensa https://dl.espressif.com/dl/xtensa-lx10 ... 2.0.tar.gz
tezaman
Postby tezaman » Fri Nov 24, 2023 8:56 am
***ERROR*** A stack overflow in task resource_ctrl has been detected.
abort() was called at PC 0x40214f73 on core 0
PC : 0x402151c6 PS : 0x00000033 A0 : 0x402151c4 A1 : 0x3ffe81d0
A6 : 0x00000000 A7 : 0x000400e6 A8 : 0x0fa0b86b A9 : 0x00000090
A10 : 0x3ffef803 A11 : 0x00000030 A12 : 0x00000080 A13 : 0x00000007
A14 : 0x00000080 A15 : 0x3ffe9450 SAR : 0x0000001e EXCCAUSE: 0x0000001d
Backtrace: 0x402151c6:0x3ffe81d0 0x40214f76:0x3ffe81e0 0x401011cc:0x3ffe81f0 0x40101253:0x3ffe8200 0x401014a6:0x3ffe8210 0x401003c8:0x3ffe8230
tezaman
Postby tezaman » Fri Nov 24, 2023 11:13 am
i found that theres a memory leak , the heap is getting lower and lower at some point and crash ,
i have to check where this is happening
Users browsing this forum: No registered users and 123 guests
