Largest contiguous RAM for HEAP
Re: Largest contiguous RAM for HEAP
If you are going to use the IRAM memory there are limitation that you must be aware off. https://esp32.com/viewtopic.php?t=23891#p94825
If you really don't want allocations to happen in a certain area, have you tried "reserving" it by doing the allocation before the other (smaller) allocations? If you need that space temporarily, you can still try to assign memory from the "reserved" space temporarily, effectively implementing your own memory management.
A really naive solution, but it might work.
This is what I have tried:ESP_jakob wrote: ↑Wed Oct 18, 2023 10:30 amIf you really don't want allocations to happen in a certain area, have you tried "reserving" it by doing the allocation before the other (smaller) allocations? If you need that space temporarily, you can still try to assign memory from the "reserved" space temporarily, effectively implementing your own memory management.
- Reserve large block temporarly
- Do smaller things
- Free large block for large allocation
- Allocate large block (done unter the hood by std::make_unique<>())
- SOME RTOS/IDF RELATED DYNAMIC ALLOCATIONS MAY OCCUR?!?!
- Free large block (destroy unique_ptr object)
- Try to reallocate the large block with std::make_unique<>() -> error large block is not available any more
It seems that whatever dynamic allocation stuff is going on in between, maybe from RTOS and/or IDF somehow shrinks the heap area which contains the large block so that eventually one can't allocate the large contiguous block anymore.
If one could tell malloc to allocate first from D/IRAM as priority, then maybe the large block (DRAM) stays untouched.
Hmm, not an easy one, I guess...
https://docs.espressif.com/projects/esp ... ble-memory
-> "MALLOC_CAP_32BIT" allows heap_caps_malloc to allocate from IRAM.
I think there is this flag, which may influence the behaviour:
CONFIG_ESP32_IRAM_AS_8BIT_ACCESSIBLE_MEMORY
But I can't find this option any more in idf.py menuconfig, it is not in the referenced section
This flag is another interesting one https://docs.espressif.com/projects/esp ... e-internal
When SPIRAM allocation with malloc are enabled, it is possible to reserve a block of RAM for "specific needs" such as DMA etc.
If this is enabled, how do the "specific needs" allocate from this reserved memory?
As usual, via heap_caps_malloc().
Users browsing this forum: Bing [Bot] and 136 guests
