SOLVED: Overriding Compiler Options in a Component
jcolebaker
Postby jcolebaker » Thu Aug 19, 2021 9:36 pm
Hi, I'm trying to enable some compiler warnings and "treat warnings as errors" for our custom components.
I have added this to the CMakeLists.txt for the component:
target_compile_options(${COMPONENT_LIB} PRIVATE -Wall -Wextra -Werror)
I discovered that my extra options are being fed to the compiler, BUT it still doesn't fail on various warning such as unused function parameters. When I look at the full list of options when compiling one source file in the component, I see that it already has a number of warnings explicitly turned off, e.g.:
-Wno-sign-compare  -Wno-unused-parameter
I guess these are overriding my attempt to turn these warnings ON?
How do I REMOVE these existing (inherited) compiler options that I don't want? I can't see where they are coming from.
Note I don't want to remove all existing compiler options (even if I could figure out how) because there are some which look important.
mark.jeronimus
Re: Overriding Compiler Options in a Component
Postby mark.jeronimus » Mon Aug 28, 2023 10:12 am
Unfortunately, IDF *relies* on these parameters.
The way you change the 'forced' parameters is by editing `esp-idf/tools/cmake/build.cmake`. However if you disable even one of these, the entirety of IDF can't compile anymore.
I was searching for a fix for this too because I found a bug in my own software that was caused by a signed/unsigned compare.
jcolebaker
WORKAROUND: Overriding Compiler Options in a Component
Postby jcolebaker » Mon Sep 02, 2024 12:49 am
I have finally found a solution to this problem.
I have been able to add extra compiler flags with (for example):
target_compile_options(${COMPONENT_LIB} PRIVATE  -Wunused-function -Werror)
However, it didn't work for some errors (such as unused function) because the ESP-IDF build system had already added flags to explicitly turn OFF these errors.
When I looked at the compiler command line as printed out during the build, and split it into readable lines, I saw this:
-Wall
-Werror=all
-Wno-error=unused-function
-Wno-error=unused-variable
-Wno-error=unused-but-set-variable
-Wno-error=deprecated-declarations
-Wextra
-Wno-sign-compare
-Wno-enum-conversion
...etc.
So "no-error=" is used to explicitly disable some errors including unused-function. I found that if I added the following to my extra flags to explicitly turn these errors back ON, it worked:
-Werror=unused-function
-Werror=unused-variable
-Werror=unused-but-set-variable
-Werror=deprecated-declarations
I.e. my build now fails if there is an unused function or variable (yay!!).
This introduces another problem, though: certain system headers won't compile now, because they generate these errors (hence why they were disabled).
The only problem I've found so far is actually with freertos/FreeRTOS.h, and it fails due to a sign-compare warning.
The work-around is to use a wrapper for freertos/FreeRTOS.h, and use #pragma directives to temporarily disable the warning, just for that header, as follows:
// my_FreeRTOS.h:
#ifndef MY_FREERTOS_H_
#define MY_FREERTOS_H_
#pragma GCC diagnostic push
#pragma GCC diagnostic ignored "-Wsign-compare"
#pragma GCC diagnostic pop
#endif // MY_FREERTOS_H_
Then include this header instead of freertos/FreeRTOS.h
Users browsing this forum: No registered users and 163 guests
