Hello all,
I seem to be having an issue with the IDF v5.1 monitor where anytime I try to input text it seems to freeze up the monitor. I end up having to kill the python process directly to be able to get my terminal back. Has anyone experienced this?
This is an Arch system running kernel 6.4.3. The monitor outputs from the device (an ESP32-H2 in this case) just fine.
During the "Hello World" example program, if I hit a key while it is printing out the "Resetting in X..." lines the output will freeze and nothing further will print out for a few seconds.
However, attempting to run a console program results in the console prompt on the monitor, but any text entry causes it to freeze up (with no characters echoed). I can't even exit with CTRL-] at this point and I have to kill the python program directly.
Is there some way I can troubleshoot this further? I am quite new to ESP32, so apologies if I've missed some common troubleshooting steps.
v5.1 Monitor freezes with input
Re: v5.1 Monitor freezes with input
That is known behaviour. In the example app, nothing is listening on the serial port, meaning that any characters 'queue up' for the ESP32 to read, which stalls serial communication. The solution would be to either read from the serial port, or simply not press any characters in the terminal.
- ESP_Roland
Also reported here: https://github.com/espressif/esp-idf/issues/11896
Ah okay, the temporary freezing with non-console apps makes sense in that case. However, the bigger issue remains which is the (near) complete freezing of the monitor with a console app that does expect input.
Users browsing this forum: Bryght-Richard and 98 guests
