Hi Guys,
Is there any example or document describing how to gracefully use either WiFi or Ethernet connection to send or receive data?
Thanks,
Abhishek
Enabling WiFi & Ethernet together
Re: Enabling WiFi & Ethernet together
Hello Abhishek,abhishekbn wrote: ↑Thu Mar 16, 2023 11:43 amHi Guys,
Thanks,
Abhishek
So, Do you need help to send data only one specific interface like Wi-Fi or EThernet? or both together like if Wi-Fi is not connected then send data through Ethernet if connected and vice versa?
Which ESP32 IDF are you using? Because i belive there are few examples available to send data through Wi-Fi or EThernet with good explanation as well.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Hi Espressif System Developers,
I have to develop a device that is a Modbus TCP Server on ethernet but which also implements a WebServer on WiFi.
Is it possible to have an ethernet port and a wifi that can work simultaneously?
Thank you
Thank you
Hello,vlengineering wrote: ↑Tue Nov 14, 2023 1:22 pmHi Espressif System Developers,
Thank you
Yes, you can use both together as per requirements.
There will be some delay or interference you will face while using both Wi-Fi and Ethernet together because Wireless Radio and Ethernet Hardware is common, but network stack and buffer is common which i believe so that you need to have good synchronization while using it.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: No registered users and 49 guests
