gatt_server_service_table cannot change Service And charatteristics
RogerJF
Postby RogerJF » Mon Jul 25, 2022 10:20 am
I compile and download this gatt_server_service_table example I check form my mobile with BLE Tester
I can see all the services and characteristics:
Service 000000ff-000-1000-8000-008059b34fb
And the following characteristics:
0000FF001-000-1000-8000-008059b34fb
0000FF003-000-1000-8000-008059b34fb
0000FF004-000-1000-8000-008059b34fb
0000FF005-000-1000-8000-008059b34fb
Now I need two change the service UUID I found a solution on internet and I change the table in this way
//I create a New service UUID
static uint8_t CustomService_uuid[16] = {0x36, 0xa2, 0x14, 0xe0, 0x0f, 0x68, 0x11, 0xeb, 0xad, 0xc1, 0x02, 0x42, 0xac, 0x12, 0x00, x02,};// (020012ac-4202-c1ad-eb11-680fe014a236)
than
I change this
[IDX_SVC] = {{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&primary_service_uuid, ESP_GATT_PERM_READ,
sizeof(uint16_t), sizeof(GATTS_SERVICE_UUID_TEST), (uint8_t *)&GATTS_SERVICE_UUID_TEST}},
with
sizeof(uint16_t), sizeof(CustomService_uuid), (uint8_t *)&CustomService_uuid}},
I change also the device Name to be sure.
I download and run the program the name is changed but I see always the same service and characteristics.
So I try do modified all the characteristics
static const uint16_t GATTS_CHAR_UUID_TEST_A = 0xFF11;//0xFF01;
static const uint16_t GATTS_CHAR_UUID_TEST_B = 0xFF12;//0xFF02;
static const uint16_t GATTS_CHAR_UUID_TEST_C = 0xFF13;//0xFF03;
static const uint16_t GATTS_CHAR_UUID_TEST_D = 0xFF14;//0xFF04;
I rebuild and download but nothing changed. From BLE Tester I see always the old value.
Is like I cannot overwrite the configuration table.
Thanks for any help
RogerJF
abansal22
Re: gatt_server_service_table cannot change Service And charatteristics
Postby abansal22 » Mon Jul 25, 2022 1:25 pm
than
I change this
with
Thanks for any help
RogerJF
Could you paste the whole code here, it will be much help
Ankit Bansal
RogerJF
Postby RogerJF » Mon Jul 25, 2022 1:42 pm
This example code is in the Public Domain (or CC0 licensed, at your option.)
Unless required by applicable law or agreed to in writing, this
software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
CONDITIONS OF ANY KIND, either express or implied.
* This demo showcases creating a GATT database using a predefined attribute table.
* It acts as a GATT server and can send adv data, be connected by client.
* Run the gatt_client demo, the client demo will automatically connect to the gatt_server_service_table demo.
* Client demo will enable GATT server's notify after connection. The two devices will then exchange
* data.
#include "freertos/task.h"
#include "freertos/event_groups.h"
#include "esp_system.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "esp_bt.h"
#include "esp_gap_ble_api.h"
#include "esp_gatts_api.h"
#include "esp_bt_main.h"
#include "gatts_table_creat_demo.h"
#include "esp_gatt_common_api.h"
#define GATTS_TABLE_TAG "GATTS_TABLE_SRV"
#define PROFILE_NUM 1
#define PROFILE_APP_IDX 0
#define ESP_APP_ID 0x55
#define SAMPLE_DEVICE_NAME "X007_AB12C7" //"X007_AB12C4"
#define SVC_INST_ID 0
/* The max length of characteristic value. When the GATT client performs a write or prepare write operation,
* the data length must be less than GATTS_DEMO_CHAR_VAL_LEN_MAX.
#define GATTS_DEMO_CHAR_VAL_LEN_MAX 500
#define PREPARE_BUF_MAX_SIZE 1024
#define CHAR_DECLARATION_SIZE (sizeof(uint8_t))
#define ADV_CONFIG_FLAG (1 << 0)
#define SCAN_RSP_CONFIG_FLAG (1 << 1)
static uint8_t adv_config_done = 0;
uint16_t gatt_db_handle_table[HRS_IDX_NB];
typedef struct {
uint8_t *prepare_buf;
int prepare_len;
} prepare_type_env_t;
static prepare_type_env_t prepare_write_env;
//#define CONFIG_SET_RAW_ADV_DATA
#ifdef CONFIG_SET_RAW_ADV_DATA
static uint8_t raw_adv_data[] = {
/* flags */
0x02, 0x01, 0x06,
/* tx power*/
0x02, 0x0a, 0xeb,
/* service uuid */
0x03, 0x03, 0xFF, 0x00,
/* device name */
0x0f, 0x09, 'E', 'S', 'P', '_', 'G', 'A', 'T', 'T', 'S', '_', 'D','E', 'M', 'O'
static uint8_t raw_scan_rsp_data[] = {
/* flags */
0x02, 0x01, 0x06,
/* tx power */
0x02, 0x0a, 0xeb,
/* service uuid */
0x03, 0x03, 0xFF,0x00
#else
static uint8_t service_uuid[16] = {
/* LSB <--------------------------------------------------------------------------------> MSB */
//first uuid, 16bit, [12],[13] is the value
//0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80, 0x00, 0x10, 0x00, 0x00, 0xFF, 0x00, 0x00, 0x00,
0x36, 0xa2, 0x14, 0xe0, 0x0f, 0x68, 0x11, 0xeb, 0xad, 0xc1, 0x02, 0x42, 0xac, 0x12, 0x00, 0x02,
#define TEST_MANUFACTURER_DATA_LEN 17
static uint8_t test_manufacturer[TEST_MANUFACTURER_DATA_LEN] = {0x30, 0x31, 0x32, 0x33 , 0x33, 0x33, 0x33};
/* The length of adv data must be less than 31 bytes */
static esp_ble_adv_data_t adv_data = {
.set_scan_rsp = false,
.include_name = true,
.include_txpower = true,
.min_interval = 0x0006, //slave connection min interval, Time = min_interval * 1.25 msec
.max_interval = 0x0010, //slave connection max interval, Time = max_interval * 1.25 msec
.appearance = 0x00,
.manufacturer_len = 0, //TEST_MANUFACTURER_DATA_LEN,
.p_manufacturer_data = NULL, //test_manufacturer,
.service_data_len = 0,
.p_service_data = NULL,
.service_uuid_len = sizeof(service_uuid),
.p_service_uuid = service_uuid,
.flag = (ESP_BLE_ADV_FLAG_GEN_DISC | ESP_BLE_ADV_FLAG_BREDR_NOT_SPT),
// scan response data
static esp_ble_adv_data_t scan_rsp_data = {
.set_scan_rsp = true,
.appearance = 0x00,
//.manufacturer_len = 0,TEST_MANUFACTURER_DATA_LEN,
.p_manufacturer_data = NULL, //&test_manufacturer[0],
//.p_manufacturer_data = &test_manufacturer[0],
#endif /* CONFIG_SET_RAW_ADV_DATA */
static esp_ble_adv_params_t adv_params = {
.adv_int_min = 0x20,
.adv_int_max = 0x40,
.adv_type = ADV_TYPE_IND,
.own_addr_type = BLE_ADDR_TYPE_PUBLIC,
.channel_map = ADV_CHNL_ALL,
.adv_filter_policy = ADV_FILTER_ALLOW_SCAN_ANY_CON_ANY,
struct gatts_profile_inst {
esp_gatts_cb_t gatts_cb;
uint16_t gatts_if;
uint16_t app_id;
uint16_t conn_id;
uint16_t service_handle;
esp_gatt_srvc_id_t service_id;
uint16_t char_handle;
esp_bt_uuid_t char_uuid;
esp_gatt_perm_t perm;
esp_gatt_char_prop_t property;
uint16_t descr_handle;
esp_bt_uuid_t descr_uuid;
static void gatts_profile_event_handler(esp_gatts_cb_event_t event,
esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param);
/* One gatt-based profile one app_id and one gatts_if, this array will store the gatts_if returned by ESP_GATTS_REG_EVT */
static struct gatts_profile_inst heart_rate_profile_tab[PROFILE_NUM] = {
[PROFILE_APP_IDX] = {
.gatts_cb = gatts_profile_event_handler,
.gatts_if = ESP_GATT_IF_NONE, /* Not get the gatt_if, so initial is ESP_GATT_IF_NONE */
#pragma GCC diagnostic ignored "-Wunused-const-variable"
/* Service */
//static const uint16_t GATTS_SERVICE_UUID_TEST = 0x00FF;
static const uint16_t primary_service_uuid = ESP_GATT_UUID_PRI_SERVICE;
static const uint16_t character_declaration_uuid = ESP_GATT_UUID_CHAR_DECLARE;
static const uint16_t character_client_config_uuid = ESP_GATT_UUID_CHAR_CLIENT_CONFIG;
static const uint8_t char_prop_read = ESP_GATT_CHAR_PROP_BIT_READ;
static const uint8_t char_prop_write = ESP_GATT_CHAR_PROP_BIT_WRITE;
static const uint8_t char_prop_read_write_notify = ESP_GATT_CHAR_PROP_BIT_WRITE | ESP_GATT_CHAR_PROP_BIT_READ | ESP_GATT_CHAR_PROP_BIT_NOTIFY;
static const uint8_t heart_measurement_ccc[2] = {0x00, 0x00};
static const uint8_t char_value[4] = {0x11, 0x22, 0x33, 0x44};
static const uint8_t char_valueD[4] = {0x1, 0x2, 0x3, 0x4};
};// (020012ac-4202-c1ad-eb11-680fe014a236)?
//(uint8_t *)&primary_service_uuid, ESP_GATT_PERM_READ, sizeof(uint16_t), sizeof(service_uuid), (uint8_t *)&service_uuid}},
/* Full Database Description - Used to add attributes into the database */
static const esp_gatts_attr_db_t gatt_db[HRS_IDX_NB] =
// Service Declaration
[IDX_SVC] =
500, sizeof(CustomService_uuid), (uint8_t *)&CustomService_uuid}},
// sizeof(uint16_t), sizeof(CustomService_uuid), (uint8_t *)&CustomService_uuid}},
// sizeof(uint16_t), sizeof(GATTS_SERVICE_UUID_TEST), (uint8_t *)&GATTS_SERVICE_UUID_TEST}},
/* Characteristic Declaration */
[IDX_CHAR_A] =
{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_declaration_uuid, ESP_GATT_PERM_READ,
CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_read_write_notify}},
/* Characteristic Value */
[IDX_CHAR_VAL_A] =
{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&GATTS_CHAR_UUID_TEST_A, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
GATTS_DEMO_CHAR_VAL_LEN_MAX, sizeof(char_value), (uint8_t *)char_value}},
/* Client Characteristic Configuration Descriptor */
[IDX_CHAR_CFG_A] =
{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&character_client_config_uuid, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
sizeof(uint16_t), sizeof(heart_measurement_ccc), (uint8_t *)heart_measurement_ccc}},
[IDX_CHAR_D] =
CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_write}},
[IDX_CHAR_VAL_D] =
{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&GATTS_CHAR_UUID_TEST_D, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
GATTS_DEMO_CHAR_VAL_LEN_MAX, sizeof(char_valueD), (uint8_t *)char_valueD}},
[IDX_CHAR_B] =
CHAR_DECLARATION_SIZE, CHAR_DECLARATION_SIZE, (uint8_t *)&char_prop_read}},
[IDX_CHAR_VAL_B] =
{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&GATTS_CHAR_UUID_TEST_B, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
[IDX_CHAR_C] =
[IDX_CHAR_VAL_C] =
{{ESP_GATT_AUTO_RSP}, {ESP_UUID_LEN_16, (uint8_t *)&GATTS_CHAR_UUID_TEST_C, ESP_GATT_PERM_READ | ESP_GATT_PERM_WRITE,
static void gap_event_handler(esp_gap_ble_cb_event_t event, esp_ble_gap_cb_param_t *param)
switch (event) {
case ESP_GAP_BLE_ADV_DATA_RAW_SET_COMPLETE_EVT:
adv_config_done &= (~ADV_CONFIG_FLAG);
if (adv_config_done == 0){
esp_ble_gap_start_advertising(&adv_params);
break;
case ESP_GAP_BLE_SCAN_RSP_DATA_RAW_SET_COMPLETE_EVT:
adv_config_done &= (~SCAN_RSP_CONFIG_FLAG);
break;
#else
case ESP_GAP_BLE_ADV_DATA_SET_COMPLETE_EVT:
break;
case ESP_GAP_BLE_SCAN_RSP_DATA_SET_COMPLETE_EVT:
break;
#endif
case ESP_GAP_BLE_ADV_START_COMPLETE_EVT:
/* advertising start complete event to indicate advertising start successfully or failed */
if (param->adv_start_cmpl.status != ESP_BT_STATUS_SUCCESS) {
ESP_LOGE(GATTS_TABLE_TAG, "advertising start failed");
}else{
ESP_LOGI(GATTS_TABLE_TAG, "advertising start successfully");
break;
case ESP_GAP_BLE_ADV_STOP_COMPLETE_EVT:
if (param->adv_stop_cmpl.status != ESP_BT_STATUS_SUCCESS) {
ESP_LOGE(GATTS_TABLE_TAG, "Advertising stop failed");
else {
ESP_LOGI(GATTS_TABLE_TAG, "Stop adv successfully\n");
break;
case ESP_GAP_BLE_UPDATE_CONN_PARAMS_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "update connection params status = %d, min_int = %d, max_int = %d,conn_int = %d,latency = %d, timeout = %d",
param->update_conn_params.status,
param->update_conn_params.min_int,
param->update_conn_params.max_int,
param->update_conn_params.conn_int,
param->update_conn_params.latency,
param->update_conn_params.timeout);
break;
default:
break;
void example_prepare_write_event_env(esp_gatt_if_t gatts_if, prepare_type_env_t *prepare_write_env, esp_ble_gatts_cb_param_t *param)
ESP_LOGI(GATTS_TABLE_TAG, "prepare write, handle = %d, value len = %d", param->write.handle, param->write.len);
esp_gatt_status_t status = ESP_GATT_OK;
if (prepare_write_env->prepare_buf == NULL) {
prepare_write_env->prepare_buf = (uint8_t *)malloc(PREPARE_BUF_MAX_SIZE * sizeof(uint8_t));
prepare_write_env->prepare_len = 0;
ESP_LOGE(GATTS_TABLE_TAG, "%s, Gatt_server prep no mem", __func__);
status = ESP_GATT_NO_RESOURCES;
} else {
if(param->write.offset > PREPARE_BUF_MAX_SIZE) {
status = ESP_GATT_INVALID_OFFSET;
} else if ((param->write.offset + param->write.len) > PREPARE_BUF_MAX_SIZE) {
status = ESP_GATT_INVALID_ATTR_LEN;
/*send response when param->write.need_rsp is true */
if (param->write.need_rsp){
esp_gatt_rsp_t *gatt_rsp = (esp_gatt_rsp_t *)malloc(sizeof(esp_gatt_rsp_t));
if (gatt_rsp != NULL){
gatt_rsp->attr_value.len = param->write.len;
gatt_rsp->attr_value.handle = param->write.handle;
gatt_rsp->attr_value.offset = param->write.offset;
gatt_rsp->attr_value.auth_req = ESP_GATT_AUTH_REQ_NONE;
memcpy(gatt_rsp->attr_value.value, param->write.value, param->write.len);
esp_err_t response_err = esp_ble_gatts_send_response(gatts_if, param->write.conn_id, param->write.trans_id, status, gatt_rsp);
if (response_err != ESP_OK){
ESP_LOGE(GATTS_TABLE_TAG, "Send response error");
free(gatt_rsp);
}else{
ESP_LOGE(GATTS_TABLE_TAG, "%s, malloc failed", __func__);
if (status != ESP_GATT_OK){
return;
memcpy(prepare_write_env->prepare_buf + param->write.offset,
param->write.value,
param->write.len);
prepare_write_env->prepare_len += param->write.len;
void example_exec_write_event_env(prepare_type_env_t *prepare_write_env, esp_ble_gatts_cb_param_t *param){
if (param->exec_write.exec_write_flag == ESP_GATT_PREP_WRITE_EXEC && prepare_write_env->prepare_buf){
esp_log_buffer_hex(GATTS_TABLE_TAG, prepare_write_env->prepare_buf, prepare_write_env->prepare_len);
}else{
ESP_LOGI(GATTS_TABLE_TAG,"ESP_GATT_PREP_WRITE_CANCEL");
if (prepare_write_env->prepare_buf) {
free(prepare_write_env->prepare_buf);
prepare_write_env->prepare_buf = NULL;
static void gatts_profile_event_handler(esp_gatts_cb_event_t event, esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param)
switch (event) {
case ESP_GATTS_REG_EVT:{
esp_err_t set_dev_name_ret = esp_ble_gap_set_device_name(SAMPLE_DEVICE_NAME);
if (set_dev_name_ret){
ESP_LOGE(GATTS_TABLE_TAG, "set device name failed, error code = %x", set_dev_name_ret);
esp_err_t raw_adv_ret = esp_ble_gap_config_adv_data_raw(raw_adv_data, sizeof(raw_adv_data));
if (raw_adv_ret){
ESP_LOGE(GATTS_TABLE_TAG, "config raw adv data failed, error code = %x ", raw_adv_ret);
adv_config_done |= ADV_CONFIG_FLAG;
esp_err_t raw_scan_ret = esp_ble_gap_config_scan_rsp_data_raw(raw_scan_rsp_data, sizeof(raw_scan_rsp_data));
if (raw_scan_ret){
ESP_LOGE(GATTS_TABLE_TAG, "config raw scan rsp data failed, error code = %x", raw_scan_ret);
adv_config_done |= SCAN_RSP_CONFIG_FLAG;
#else
//config adv data
esp_err_t ret = esp_ble_gap_config_adv_data(&adv_data);
if (ret){
ESP_LOGE(GATTS_TABLE_TAG, "config adv data failed, error code = %x", ret);
//config scan response data
ret = esp_ble_gap_config_adv_data(&scan_rsp_data);
if (ret){
ESP_LOGE(GATTS_TABLE_TAG, "config scan response data failed, error code = %x", ret);
#endif
ESP_LOGI(GATTS_TABLE_TAG,"esp_ble_gatts_create_attr_tab");
esp_err_t create_attr_ret = esp_ble_gatts_create_attr_tab(gatt_db, gatts_if, HRS_IDX_NB, SVC_INST_ID);
if (create_attr_ret){
ESP_LOGE(GATTS_TABLE_TAG, "create attr table failed, error code = %x", create_attr_ret);
break;
case ESP_GATTS_READ_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_READ_EVT");
break;
case ESP_GATTS_WRITE_EVT:
if (!param->write.is_prep){
// the data length of gattc write must be less than GATTS_DEMO_CHAR_VAL_LEN_MAX.
ESP_LOGI(GATTS_TABLE_TAG, "GATT_WRITE_EVT, handle = %d, value len = %d, value :", param->write.handle, param->write.len);
esp_log_buffer_hex(GATTS_TABLE_TAG, param->write.value, param->write.len);
#ifdef TOLTO
if (heart_rate_handle_table[IDX_CHAR_CFG_A] == param->write.handle && param->write.len == 2){
uint16_t descr_value = param->write.value[1]<<8 | param->write.value[0];
if (descr_value == 0x0001){
ESP_LOGI(GATTS_TABLE_TAG, "notify enable");
uint8_t notify_data[15];
for (int i = 0; i < sizeof(notify_data); ++i)
notify_data = i % 0xff;
//the size of notify_data[] need less than MTU size
esp_ble_gatts_send_indicate(gatts_if, param->write.conn_id, heart_rate_handle_table[IDX_CHAR_VAL_A],
sizeof(notify_data), notify_data, false);
}else if (descr_value == 0x0002){
ESP_LOGI(GATTS_TABLE_TAG, "indicate enable");
uint8_t indicate_data[15];
for (int i = 0; i < sizeof(indicate_data); ++i)
indicate_data = i % 0xff;
//the size of indicate_data[] need less than MTU size
sizeof(indicate_data), indicate_data, true);
else if (descr_value == 0x0000){
ESP_LOGI(GATTS_TABLE_TAG, "notify/indicate disable ");
}else{
ESP_LOGE(GATTS_TABLE_TAG, "unknown descr value");
/* send response when param->write.need_rsp is true*/
esp_ble_gatts_send_response(gatts_if, param->write.conn_id, param->write.trans_id, ESP_GATT_OK, NULL);
#endif
}else{
/* handle prepare write */
example_prepare_write_event_env(gatts_if, &prepare_write_env, param);
break;
case ESP_GATTS_EXEC_WRITE_EVT:
// the length of gattc prepare write data must be less than GATTS_DEMO_CHAR_VAL_LEN_MAX.
ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_EXEC_WRITE_EVT");
example_exec_write_event_env(&prepare_write_env, param);
break;
case ESP_GATTS_MTU_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_MTU_EVT, MTU %d", param->mtu.mtu);
break;
case ESP_GATTS_CONF_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_CONF_EVT, status = %d, attr_handle %d", param->conf.status, param->conf.handle);
break;
case ESP_GATTS_START_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "SERVICE_START_EVT, status %d, service_handle %d", param->start.status, param->start.service_handle);
break;
case ESP_GATTS_CONNECT_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_CONNECT_EVT, conn_id = %d", param->connect.conn_id);
esp_log_buffer_hex(GATTS_TABLE_TAG, param->connect.remote_bda, 6);
esp_ble_conn_update_params_t conn_params = {0};
memcpy(conn_params.bda, param->connect.remote_bda, sizeof(esp_bd_addr_t));
/* For the iOS system, please refer to Apple official documents about the BLE connection parameters restrictions. */
conn_params.latency = 0;
conn_params.max_int = 0x20; // max_int = 0x20*1.25ms = 40ms
conn_params.min_int = 0x10; // min_int = 0x10*1.25ms = 20ms
conn_params.timeout = 400; // timeout = 400*10ms = 4000ms
//start sent the update connection parameters to the peer device.
esp_ble_gap_update_conn_params(&conn_params);
break;
case ESP_GATTS_DISCONNECT_EVT:
ESP_LOGI(GATTS_TABLE_TAG, "ESP_GATTS_DISCONNECT_EVT, reason = 0x%x", param->disconnect.reason);
break;
case ESP_GATTS_CREAT_ATTR_TAB_EVT:{
if (param->add_attr_tab.status != ESP_GATT_OK){
ESP_LOGE(GATTS_TABLE_TAG, "create attribute table failed, error code=0x%x", param->add_attr_tab.status);
else if (param->add_attr_tab.num_handle != HRS_IDX_NB){
ESP_LOGE(GATTS_TABLE_TAG, "create attribute table abnormally, num_handle (%d) \
doesn't equal to HRS_IDX_NB(%d)", param->add_attr_tab.num_handle, HRS_IDX_NB);
else {
ESP_LOGI(GATTS_TABLE_TAG, "TOLTO create attribute table successfully, the number handle = %d\n",param->add_attr_tab.num_handle);
//memcpy(heart_rate_handle_table, param->add_attr_tab.handles, sizeof(heart_rate_handle_table));
//esp_ble_gatts_start_service(heart_rate_handle_table[IDX_SVC]);
memcpy(gatt_db_handle_table, param->add_attr_tab.handles, sizeof(gatt_db_handle_table));
esp_ble_gatts_start_service(gatt_db_handle_table[IDX_SVC]);
break;
case ESP_GATTS_STOP_EVT:
case ESP_GATTS_OPEN_EVT:
case ESP_GATTS_CANCEL_OPEN_EVT:
case ESP_GATTS_CLOSE_EVT:
case ESP_GATTS_LISTEN_EVT:
case ESP_GATTS_CONGEST_EVT:
case ESP_GATTS_UNREG_EVT:
case ESP_GATTS_DELETE_EVT:
default:
break;
static void gatts_event_handler(esp_gatts_cb_event_t event, esp_gatt_if_t gatts_if, esp_ble_gatts_cb_param_t *param)
/* If event is register event, store the gatts_if for each profile */
if (event == ESP_GATTS_REG_EVT) {
if (param->reg.status == ESP_GATT_OK) {
heart_rate_profile_tab[PROFILE_APP_IDX].gatts_if = gatts_if;
} else {
ESP_LOGE(GATTS_TABLE_TAG, "reg app failed, app_id %04x, status %d",
param->reg.app_id,
param->reg.status);
return;
do {
int idx;
for (idx = 0; idx < PROFILE_NUM; idx++) {
/* ESP_GATT_IF_NONE, not specify a certain gatt_if, need to call every profile cb function */
if (gatts_if == ESP_GATT_IF_NONE || gatts_if == heart_rate_profile_tab[idx].gatts_if) {
if (heart_rate_profile_tab[idx].gatts_cb) {
heart_rate_profile_tab[idx].gatts_cb(event, gatts_if, param);
} while (0);
void app_main(void)
esp_err_t ret;
/* Initialize NVS. */
ret = nvs_flash_init();
if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND) {
ESP_ERROR_CHECK(nvs_flash_erase());
ESP_ERROR_CHECK( ret );
ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_CLASSIC_BT));
esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
ret = esp_bt_controller_init(&bt_cfg);
if (ret) {
ESP_LOGE(GATTS_TABLE_TAG, "%s enable controller failed: %s", __func__, esp_err_to_name(ret));
return;
ret = esp_bt_controller_enable(ESP_BT_MODE_BLE);
if (ret) {
return;
ret = esp_bluedroid_init();
if (ret) {
ESP_LOGE(GATTS_TABLE_TAG, "%s init bluetooth failed: %s", __func__, esp_err_to_name(ret));
return;
ret = esp_bluedroid_enable();
if (ret) {
ESP_LOGE(GATTS_TABLE_TAG, "%s enable bluetooth failed: %s", __func__, esp_err_to_name(ret));
return;
ret = esp_ble_gatts_register_callback(gatts_event_handler);
if (ret){
ESP_LOGE(GATTS_TABLE_TAG, "gatts register error, error code = %x", ret);
return;
ret = esp_ble_gap_register_callback(gap_event_handler);
if (ret){
ESP_LOGE(GATTS_TABLE_TAG, "gap register error, error code = %x", ret);
return;
ret = esp_ble_gatts_app_register(ESP_APP_ID);
if (ret){
ESP_LOGE(GATTS_TABLE_TAG, "gatts app register error, error code = %x", ret);
return;
esp_err_t local_mtu_ret = esp_ble_gatt_set_local_mtu(500);
if (local_mtu_ret){
ESP_LOGE(GATTS_TABLE_TAG, "set local MTU failed, error code = %x", local_mtu_ret);
//console output
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x40376657
0x40376657: _xt_user_exc at C:/Espressif/frameworks/esp-idf-v4.4/components/freertos/port/xtensa/xtensa_vectors.S:624
pro cpu reset by JTAG
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd0108,len:0x1650
load:0x403b6000,len:0xb7c
load:0x403ba000,len:0x2f58
entry 0x403b6248
I (31) boot: ESP-IDF v4.4-dirty 2nd stage bootloader
I (31) boot: compile time 12:27:48
I (31) boot: chip revision: 0
I (33) boot.esp32s3: Boot SPI Speed : 80MHz
I (38) boot.esp32s3: SPI Mode : DIO
I (43) boot.esp32s3: SPI Flash Size : 2MB
I (47) boot: Enabling RNG early entropy source...
I (53) boot: Partition Table:
I (56) boot: ## Label Usage Type ST Offset Length
I (64) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (71) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (79) boot: 2 factory factory app 00 00 00010000 00100000
I (86) boot: End of partition table
I (90) esp_image: segment 0: paddr=00010020 vaddr=3c080020 size=1cda4h (118180) map
I (120) esp_image: segment 1: paddr=0002cdcc vaddr=3fc93e00 size=0324ch ( 12876) load
I (123) esp_image: segment 2: paddr=00030020 vaddr=42000020 size=713b8h (463800) map
I (209) esp_image: segment 3: paddr=000a13e0 vaddr=3fc9704c size=00618h ( 1560) load
I (210) esp_image: segment 4: paddr=000a1a00 vaddr=40374000 size=0fdf4h ( 65012) load
I (229) esp_image: segment 5: paddr=000b17fc vaddr=50000000 size=00010h ( 16) load
I (236) boot: Loaded app from partition at offset 0x10000
I (236) boot: Disabling RNG early entropy source...
I (249) cpu_start: Pro cpu up.
I (249) cpu_start: Starting app cpu, entry point is 0x40375164
0x40375164: call_start_cpu1 at C:/Espressif/frameworks/esp-idf-v4.4/components/esp_system/port/cpu_start.c:156
I (0) cpu_start: App cpu up.
I (263) cpu_start: Pro cpu start user code
I (263) cpu_start: cpu freq: 160000000
I (264) cpu_start: Application information:
I (266) cpu_start: Project name: gatt_server_service_table
I (273) cpu_start: App version: 1
I (277) cpu_start: Compile time: Jul 25 2022 12:26:51
I (283) cpu_start: ELF file SHA256: e688351dc1093ee6...
I (289) cpu_start: ESP-IDF: v4.4-dirty
I (295) heap_init: Initializing. RAM available for dynamic allocation:
I (302) heap_init: At 3FC9B4D0 len 00044B30 (274 KiB): D/IRAM
I (308) heap_init: At 3FCE0000 len 0000EE34 (59 KiB): STACK/DRAM
I (315) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (322) spi_flash: detected chip: generic
I (326) spi_flash: flash io: dio
W (330) spi_flash: Detected size(8192k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (343) sleep: Configure to isolate all GPIO pins in sleep state
I (350) sleep: Enable automatic switching of GPIO sleep configuration
I (357) coexist: coexist rom version e7ae62f
I (362) cpu_start: Starting scheduler on PRO CPU.
W (406) BT_INIT: esp_bt_controller_mem_release not implemented, return OK
I (406) BT_INIT: BT controller compile version [6881869]
I (406) phy_init: phy_version 302,3ddfab3,Dec 3 2021,14:39:12
I (466) system_api: Base MAC address is not set
I (466) system_api: read default base MAC address from EFUSE
I (466) BT_INIT: Bluetooth MAC: 7c:df:a1:e2:85:d6
I (496) GATTS_TABLE_SRV: esp_ble_gatts_create_attr_tab
W (496) BT_BTM: BTM_BleWriteAdvData, Partial data write into ADV
W (496) BT_BTM: BTM_BleWriteScanRsp, Partial data write into ADV
I (506) GATTS_TABLE_SRV: TOLTO create attribute table successfully, the number handle = 10
I (516) GATTS_TABLE_SRV: SERVICE_START_EVT, status 0, service_handle 40
I (516) GATTS_TABLE_SRV: advertising start successfully
Build:Mar 27 2021
Saved PC:0x40376657
SPIWP:0xee
entry 0x403b6248
W (8308) BT_INIT: esp_bt_controller_mem_release not implemented, return OK
I (8308) BT_INIT: BT controller compile version [6881869]
I (8308) phy_init: phy_version 302,3ddfab3,Dec 3 2021,14:39:12
I (8368) system_api: Base MAC address is not set
I (8368) system_api: read default base MAC address from EFUSE
I (8368) BT_INIT: Bluetooth MAC: 7c:df:a1:e2:85:d6
I (8398) GATTS_TABLE_SRV: esp_ble_gatts_create_attr_tab
W (8398) BT_BTM: BTM_BleWriteAdvData, Partial data write into ADV
W (8398) BT_BTM: BTM_BleWriteScanRsp, Partial data write into ADV
I (13318) GATTS_TABLE_SRV: TOLTO create attribute table successfully, the number handle = 10
I (13318) GATTS_TABLE_SRV: SERVICE_START_EVT, status 0, service_handle 40
I (13318) GATTS_TABLE_SRV: advertising start successfully
I (24548) GATTS_TABLE_SRV: ESP_GATTS_CONNECT_EVT, conn_id = 0
I (24558) GATTS_TABLE_SRV: 71 bf 5a 08 e9 47
I (25368) GATTS_TABLE_SRV: update connection params status = 0, min_int = 16, max_int = 32,conn_int = 32,latency = 0, timeout = 400
//Attached the screen shot of my BLE TEster App
Users browsing this forum: Google [Bot] and 96 guests
