Is slave latency the same as maxi_skip ?
666hjk
Postby 666hjk » Thu Jul 07, 2022 3:54 pm
The struct below have a parameter as max_skip, is this the same as slave latency? I search the documentation on max_skip , can't find any info on it. pls advise. Thanks
typedef struct {
esp_ble_ext_adv_type_mask_t type; /*!< ext adv type */
uint32_t interval_min; /*!< ext adv minimum interval */
uint32_t interval_max; /*!< ext adv maximum interval */
esp_ble_adv_channel_t channel_map; /*!< ext adv channel map */
esp_ble_addr_type_t own_addr_type; /*!< ext adv own addresss type */
esp_ble_addr_type_t peer_addr_type; /*!< ext adv peer address type */
esp_bd_addr_t peer_addr; /*!< ext adv peer address */
esp_ble_adv_filter_t filter_policy; /*!< ext adv filter policy */
int8_t tx_power; /*!< ext adv tx power */
esp_ble_gap_pri_phy_t primary_phy; /*!< ext adv primary phy */
uint8_t max_skip; /*!< ext adv maximum skip */
esp_ble_gap_phy_t secondary_phy; /*!< ext adv secondary phy */
uint8_t sid; /*!< ext adv sid */
bool scan_req_notif; /*!< ext adv sacn request event notify */
} esp_ble_gap_ext_adv_params_t;
学习中找战友。
Users browsing this forum: Google [Bot] and 80 guests
