Using ESP32 WROOM modules outdoors in sunlight, temperature margin
Posted: Sun Nov 18, 2018 12:33 pm
I have a street lighting project for which I plan to use ESP32 WROOM modules.
Since the street lights are going to be in sun (summers get pretty hot where these are going to be used), is it okay to use these modules at temperatures of strong direct sunlight, the modules max temp is 85 degrees as per datasheet?
Given that the electronics also will generate a bit heat, is there sufficient margin?
Thanks,
WI
Thanks,
WI
