QUESTION - ESP32-D2WD + External ESP-PSRAM64
Posted: Wed Aug 29, 2018 1:25 pm
I purchased and received 3k ESP32-D2WD and 3k ESP-PSRAM64 chips.
I'm designing a board with the ESP32-D2WD and with the ESP-PSRAM64.
At page 9 of the 2.5 version of the datasheet I'm reading this:
"ESP32-D2WD’s pins GPIO16, GPIO17, SD_CMD, SD_CLK, SD_DATA_0 and SD_DATA_1 are used for connecting
the embedded flash, and are not recommended for other uses."
source: https://www.espressif.com/sites/default ... eet_en.pdf
QUESTION 1
Can I use the ESP-PSRAM64 with the ESP32-D2WD?
if yes, how can I glue them?
QUESTION 2
Did you address the internal flash memory in the address space of the PSRAM??????
Best regards,
Enrico Migliore
QUESTION 1
QUESTION 2
Best regards,
Enrico Migliore
