MD5 of file does not match data in flash!
Posted: Mon Feb 17, 2025 4:53 pm
I'm using ESP32-S3FN8 and CH340 USB to TTL Programmer. but whenever I try to Flash the chip it gives me this error:
I tried to clean the Flash using this command:
I seems to be cleaned but whenever I restart it it keeps printing this message: invalid header: 0xffffffff
I tried to launch it on boot mode the message it shows is this:
The code itself is just an empty template. Flash size is set to 8MB. Baudrate is set to 115200 and the command I'm using is this:File md5: dd5a757295421a46b1585bd27be7beb2
Flash md5: f6e84a245ec15ff98f659e6f703ad42d
MD5 of 0xFF is f6e84a245ec15ff98f659e6f703ad42d
A fatal error occurred: MD5 of file does not match data in flash!
esptool.py -p COM3 -b 115200 --before default_reset --after hard_reset --chip esp32s3 write_flash --flash_mode dio --flash_freq 80m --flash_size 8MB 0x00 bootloader/bootloader.bin 0x10000 Examp_code.bin 0x8000 partition_table/partition-table.bin
idf.py erase_flash
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x20 (DOWNLOAD(USB/UART0))
waiting for download
