Unable to compress strings
alkhachatryan
Postby alkhachatryan » Wed Sep 11, 2024 1:35 pm
I'm using miniz.h to compress a simple string with ONE letter.
  // Example string to compress
    const char* originalString = "T";
    size_t originalLength = strlen(originalString) + 1; // +1 for null terminator
    // Allocate memory for compressed data
    mz_ulong compressedLength = compressBound(originalLength); // Use mz_ulong
    Serial.println("Free size:");
    Serial.println(esp_get_free_heap_size());
    Serial.println("Needed size:");
    Serial.println(compressedLength);
    unsigned char* compressedData = (unsigned char*)malloc(compressedLength);
    if (compressedData == NULL) {
        Serial.println("Failed to allocate memory for compressed data");
        return;
    // Compress the string
    int status = compress(compressedData, &compressedLength, (const unsigned char*)originalString, originalLength);
    if (status != Z_OK) {
        Serial.print("Compression failed with status: ");
        Serial.println(status);
        free(compressedData);
        return;
    Serial.print("Compressed length: ");
    // Allocate memory for decompressed data
    unsigned char* decompressedData = (unsigned char*)malloc(originalLength);
    if (decompressedData == NULL) {
        Serial.println("Failed to allocate memory for decompressed data");
        return;
    // Decompress the string
    mz_ulong decompressedLength = originalLength; // Use mz_ulong
    status = uncompress(decompressedData, &decompressedLength, compressedData, compressedLength);
        Serial.print("Decompression failed with status: ");
        free(decompressedData);
        return;
    Serial.print("Decompressed length: ");
    Serial.println(decompressedLength);
    // Print the decompressed string
    Serial.print("Decompressed string: ");
    Serial.println((char*)decompressedData);
    // Free allocated memory
So every time I get -4 error telling that there is an issue of memory. But the debug shows me the following:
Free size:
298036
Needed size:
135
Compression failed with status: -4
I cannot understand what's wrong with it.
Hardware
ESP32 Wroom 32u
IDE
VSCode + PlatformIO
platformio.ini
[env:esp32dev2]
platform = espressif32
board = nodemcu-32s
framework = arduino, espidf
upload_port = /dev/ttyUSB1
monitor_port = /dev/ttyUSB1
monitor_speed = 115200
lib_extra_dirs = /home/alexey/Projects/DTLP/DTLP
upload_speed = 921600
; Configure flash settings
board_build.f_flash = 40000000
board_build.flash_mode = qio
board_build.flash_size = 4MB
board_build.cpu_freq = 240MHz
board_build.partitions = partitions.csv
board_build.mcu = esp32
board_build.psram = one
board_upload.flash_erase = true
; Configure events to run on core 1 (if needed, this is more for multi-core setups)
build_flags =
    -D ARDUINO_RUNNING_CORE=1
    -Ilib/miniz
    -Ilib/heatshrink
    -DBOARD_HAS_PSRAM
partitions.csv
# Name,	Type,	SubType,	Offset,	Size,	Flags
nvs,	data,	nvs,	0x9000,	0x5000,
otadata,	data,	ota,	0xe000,	0x2000,
app0,	app,	ota_0,	0x10000,	0x140000,
app1,	app,	ota_1,	0x150000,	0x140000,
spiffs,	data,	spiffs,	0x290000,	0x160000,
coredump,	data,	coredump,	0x3f0000,	0x10000,
So again, everything shows I have enough memory to compress a single "T" letter, but I have an error while trying to allocate memory for that.
ESP_Sprite
Re: Unable to compress strings
Postby ESP_Sprite » Thu Sep 12, 2024 1:31 am
miniz needs a bunch of space to allocate data structures that are needed for compression, e.g. for the dictionary. Could be that you don't have enough (contiguous) memory for that, making the call fail.
alkhachatryan
Postby alkhachatryan » Thu Sep 12, 2024 11:48 am
So maybe I need to play with partitions? What to do for this case? My chip is esp32 wroom 32u. What to enable/configure? If there is miniz lib for esp32 - we must to be able to use. Otherwise it's garbage. So the question is: what to do to use it?
ESP_Sprite
Postby ESP_Sprite » Thu Sep 12, 2024 1:51 pm
We're not talking about flash here, we're talking about RAM. And I'm sorry, but I can't tell you exactly what is going wrong - 300K seems enough RAM to me, but perhaps your RAM is fragmented and miniz tries to allocate a large contiguous buffer.
alkhachatryan
Postby alkhachatryan » Thu Sep 12, 2024 3:45 pm
I didn't do anything from my side to make fragments. Can you tell me please what and where to check?
What I need - just send signals to digital pins, read from them and use compression, that's it. I send data through laser and just want to compress before sending
MicroController
Postby MicroController » Fri Sep 13, 2024 7:35 pm
Can you share some more code to help us narrow down your issue?
Users browsing this forum: Baidu [Spider] and 30 guests
