Read/Write Protect & eFuses (Simplified)
Posted: Wed Mar 06, 2024 3:00 pm
by ESPecially_Embedded
I have some basic questions regarding functionality of the read/write protection and eFuses which I'm unable to clarify from the documentation and existing forums.
Facts about my code
No personal data will be stored, no ota partition is available and WiFi not configured.
What I'm struggling with
I want to protect my firmware from being easily read or modified but I also need to be able to erase and reflash the firmware. Can I achieve this? I've looked at Encryption but I'm concerned by being limited to three plain text reflashes and encrypting it from a static key on my PC is not possible as PlatformIO/ArduinoEspressif doesn't support use of idf.py to create the encrypted binaries.
Essentially I want to enable read/write protection which is available on PIC microprocessors, this is what I'm used to. In this case you cannot read or write via the programming port unless a 'bulk erase' is performed. Does the ESP32 have any similar functionality?
Notes
I intend to burn the efuses using the API or using espefuse.py via PIO.
Here is my current eFuse summary, factory default.
=== Run "summary" command ===
EFUSE_NAME (Block) Description  = [Meaningful Value] [Readable/Writeable] (Hex Value)
Calibration fuses:
BLK3_PART_RESERVE (BLOCK0):                        BLOCK3 partially served for ADC calibration data   = False R/W (0b0)
ADC_VREF (BLOCK0):                                 Voltage reference calibration                      = 1135 R/W (0b00101)
Config fuses:
XPD_SDIO_FORCE (BLOCK0):                           Ignore MTDI pin (GPIO12) for VDD_SDIO on reset     = False R/W (0b0)
XPD_SDIO_REG (BLOCK0):                             If XPD_SDIO_FORCE, enable VDD_SDIO reg on reset    = False R/W (0b0)
XPD_SDIO_TIEH (BLOCK0):                            If XPD_SDIO_FORCE & XPD_SDIO_REG                   = 1.8V R/W (0b0)
CLK8M_FREQ (BLOCK0):                               8MHz clock freq override                           = 55 R/W (0x37)
SPI_PAD_CONFIG_CLK (BLOCK0):                       Override SD_CLK pad (GPIO6/SPICLK)                 = 0 R/W (0b00000)
SPI_PAD_CONFIG_Q (BLOCK0):                         Override SD_DATA_0 pad (GPIO7/SPIQ)                = 0 R/W (0b00000)
SPI_PAD_CONFIG_D (BLOCK0):                         Override SD_DATA_1 pad (GPIO8/SPID)                = 0 R/W (0b00000)
SPI_PAD_CONFIG_HD (BLOCK0):                        Override SD_DATA_2 pad (GPIO9/SPIHD)               = 0 R/W (0b00000)
SPI_PAD_CONFIG_CS0 (BLOCK0):                       Override SD_CMD pad (GPIO11/SPICS0)                = 0 R/W (0b00000)
DISABLE_SDIO_HOST (BLOCK0):                        Disable SDIO host                                  = False R/W (0b0)
Efuse fuses:
WR_DIS (BLOCK0):                                   Efuse write disable mask                           = 0 R/W (0x0000)
RD_DIS (BLOCK0):                                   Efuse read disable mask                            = 0 R/W (0x0)
CODING_SCHEME (BLOCK0):                            Efuse variable block length scheme
   = NONE (BLK1-3 len=256 bits) R/W (0b00)
KEY_STATUS (BLOCK0):                               Usage of efuse block 3 (reserved)                  = False R/W (0b0)
Identity fuses:
MAC (BLOCK0):                                      Factory MAC Address
   = 84:cc:a8:5e:b8:50 (CRC 0xa0 OK) R/W
MAC_CRC (BLOCK0):                                  CRC8 for factory MAC address                       = 160 R/W (0xa0)
CHIP_VER_REV1 (BLOCK0):                            Silicon Revision 1                                 = True R/W (0b1)
CHIP_VER_REV2 (BLOCK0):                            Silicon Revision 2                                 = False R/W (0b0)
WAFER_VERSION_MINOR (BLOCK0):                      WAFER VERSION MINOR                                = 0 R/W (0b00)
CHIP_PACKAGE (BLOCK0):                             Chip package identifier                            = 0 R/W (0b000)
CHIP_PACKAGE_4BIT (BLOCK0):                        Chip package identifier #4bit                      = 0 R/W (0b0)
MAC_VERSION (BLOCK3):                              Version of the MAC field                           = 0 R/W (0x00)
WAFER_VERSION_MAJOR (BLOCK0):                      calc WAFER VERSION MAJOR from CHIP_VER_REV1 and CH = 1 R/W (0b001)
                                                   IP_VER_REV2 and apb_ctl_date (read only)
PKG_VERSION (BLOCK0):                              calc Chip package = CHIP_PACKAGE_4BIT << 3 + CHIP_ = 0 R/W (0x0)
                                                   PACKAGE (read only)
Security fuses:
FLASH_CRYPT_CNT (BLOCK0):                          Flash encryption mode counter                      = 0 R/W (0b0000000)
UART_DOWNLOAD_DIS (BLOCK0):                        Disable UART download mode (ESP32 rev3 only)       = False R/W (0b0)
FLASH_CRYPT_CONFIG (BLOCK0):                       Flash encryption config (key tweak bits)           = 0 R/W (0x0)
CONSOLE_DEBUG_DISABLE (BLOCK0):                    Disable ROM BASIC interpreter fallback             = True R/W (0b1)
ABS_DONE_0 (BLOCK0):                               Secure boot V1 is enabled for bootloader image     = False R/W (0b0)
ABS_DONE_1 (BLOCK0):                               Secure boot V2 is enabled for bootloader image     = False R/W (0b0)
JTAG_DISABLE (BLOCK0):                             Disable JTAG                                       = False R/W (0b0)
DISABLE_DL_ENCRYPT (BLOCK0):                       Disable flash encryption in UART bootloader        = False R/W (0b0)
DISABLE_DL_DECRYPT (BLOCK0):                       Disable flash decryption in UART bootloader        = False R/W (0b0)
DISABLE_DL_CACHE (BLOCK0):                         Disable flash cache in UART bootloader             = False R/W (0b0)
BLOCK1 (BLOCK1):                                   Flash encryption key
   = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
BLOCK2 (BLOCK2):                                   Secure boot key
BLOCK3 (BLOCK3):                                   Variable Block 3
Re: Read/Write Protect & eFuses (Simplified)
Posted: Fri Mar 08, 2024 8:20 am
Realised I haven't specified what I'm compiling to! It's an ESP32-WROOM-32, chip v1. Any guidance from ESP staff or otherwise would be greatly appreciated.
Posted: Fri Mar 08, 2024 1:04 pm
by MicroController
Posted: Mon Mar 18, 2024 10:33 am
Query resolved - see my other related post:
viewtopic.php?f=13&t=38777&p=129402#p129402
