What flash memory chip to use
Posted: Thu Jan 18, 2024 7:09 pm
by don.vukovic
I would like to upgrade the flash memory chip in the ESP32-WROOM module.
What part number should I use ?
Re: What flash memory chip to use
Posted: Sat Jan 20, 2024 9:23 pm
by JohnnyZ
Mine ESP32-C3-WROOM-02 module after delidding shows XMO 25qh32 SOIC-8 3V flash, so probably something like that but with more capacity.
But note that if you use flash with different voltage you'll need to burn some efuses. Also components around that flash on WROOM module are tiny and knocking something out while soldering means that your module will be unusable.
