Esp32+wled alimentation
Posted: Fri Jan 20, 2023 11:23 am
I bought the esp32 controller and I would like to connect WS2812B leds (5V 5050 150 LEDs IP30).
The red wire of the led is connected to the 5v pin, the white to the Gnd pin and the green to the G16 pin.
Then simultaneously I connect the micro usb cable to the pc on the usb 2.0/3.0 port. Everything works, but I would like to be sure that the connections are correct and not to break the controller or pc.
I attach Pinout Diagram of my controller esp32: There are 2 Gnd pins, I'm using the first one on the top right. All right?
Sorry for the question but i'm trying to learn, it's my first esp32 controller.
thank you !
thank you !
