ESP32-C3 MINI-1 module programming
Posted: Fri Nov 25, 2022 2:14 pm
Hi, I purchased a couple of ESP32-C3 mini modules for a project. The modules are being mounted on PCB board, I tried to flash/program them for the application using a customized board (simplified schematic of esp32-c3 dev-board). The issue is that the system is unable to communicate with the module. I also replaced the module on an esp32-c3-mini dev board with the purchased one but still facing the same issue with the flashing. The question is that:
Whether the esp32-c3 modules, in the market, are required to be pre-programmed prior to the flashing process?
How I can flash the modules?
Any help/comment/guide will be appreciated!
Best Regards,
Mahdi
Best Regards,
Mahdi
