ESP32-WROOM direct external QSPI flash for mass production programming
Posted: Tue May 03, 2022 1:07 pm
For ESP32-WROOM, is there any documentation or guidance on connecting and directly programming the ext QSPI flash chip instead of serial programming via esp32 chip and esp_tool.py?
Most QSPI chips these days support 100Mhz as opposed to much slower process of going through ESP32.
The datasheet for ESP32WROOM says:
Appreciate your input.
-a
Not sure if this means we can't connect to the ext SPI, or the pin mapping they used."Pins GPIO6 to GPIO11 on the ESP32-D0WD-V3 chip are connected to the SPI flash integrated on the
module and are not led out."
-a
