D2WD Processor Doesn't Run
Posted: Sun Jul 05, 2020 10:06 pm
I recently had a PCB printed, and was having some difficulty communicating to if via the built in CP2102N chip I added to it.
However, I put a few extra jumpers on the board, and managed to upload the code using a separate CP2102 board.
https://www.robotshop.com/ca/en/cp2102m ... board.html
I just make sure to have GPIO0 grounded when doing the software upload.
However, when I remove the ground to GPIO0, and reset the power, the program does not seem to work. I tried a basic LED blink test on a few different pins, and, simply wanted it to do a Serial.println("beep") in the loop(). Nothing appears on the serial line.
At some point, I have to consider that the PCB is defective if I can't get this to respond. I used 6mil resolution when printing them (they told me it would be sufficient for this processor). Has anyone out there had any success designing a board using one of the ESP32 chips on a custom board? Very frustrated at this point..
