Recommend a voltage regulator/buck converter for ESP32 project
Posted: Thu Jun 13, 2019 3:40 am
Hi all,
I am working on a ESP32 project that is powered by 3.7V Lipo batteries. I need the circuit to have very low current consumption when the ESP32 is in sleep mode.
I was looking at the ESP32-MeshKit-Sense Hardware Design Guidelines (https://github.com/espressif/esp-iot-so ... uide_en.md) and it recommends a ETA3425 for the power supply management portion. The ETA3425 is a 1uA Ultra-Low Quiescent Current 0.6A Output Sync BUCK.
This part seems hard to purchase and is not easily available on Digikey/Mouser etc. Is there a similar part that I can use? Would anyone be able to recommend something that you have used in your project?
Also, what is the reason for using a buck converter in the reference design? Why wouldn't a regular LDO work? I used the MIC5219-3.3 extensively in many of my designs for battery powered projects in the past. Am I doing something wrong all this while with just using a standard LDO?
Thanks in advance!
Thanks in advance!
