Need help with ESP32 module selection for a new project
Squirrelbd
Postby Squirrelbd » Tue Mar 22, 2022 4:59 am
I am currently working on a project and have already done most of the r&d using the ESP32-WROOM-32 board. Now I am going to design PCB with onboard ESP32 cheap. But, I want to choose a new and stable version of ESP32. As suggested by Espressif, the ESP32-WROOM-32 is NRND(Not recommended for new designs). So I am a little bit confused about the future ESP32 cheap availability and production of this certain model. I have chosen some models as mentioned below:
-ESP32-WROOM-1-N8R2
-ESP32-WROVER-E-N4R8
-ESP32-S2-MINI-1-N4
-ESP32-WROVER-E
-ESP32-WROVER-B
Can anyone please suggest which board is stable, available, and will be available for a long time? Thanks!
Note: My project is IOT based simple sensor data transection and sometimes switching like this.
ESP_Minatel
Re: Need help with ESP32 module selection for a new project
Postby ESP_Minatel » Tue Mar 22, 2022 4:50 pm
You can use the ESP32-WROOM-32E as a replacement for the old.
The ESP32-WROOM-32 is NRND due to the new ESP32-D0WD-V3.
If you are afraid about availability, please see this longevity commitment.
Squirrelbd
Postby Squirrelbd » Tue Mar 22, 2022 5:29 pm
Thanks for your quick response. Can you please suggest to me should I go for ESP32-S3-WROOM-1? Considering the NRND and support perspective. Now I know about the 12years production guarantee.
ESP_Minatel
Postby ESP_Minatel » Wed Mar 23, 2022 11:26 am
It's hard to suggest you just based on the lifecycle. If your project is a commercial product and the excepted lifetime is long, you need to consider updating your project before the ESP32 EOL.
The ESP32-S3-WROOM-1 is from a different ESP32 family you need to consider all the peripherals you will use and compare to both chips. However, if you are considering using the modules for the project you've shared, the ESP32-WROOM-32E works like a charm.
If you still have questions regarding the longevity commitment, don't hesitate to contact our sales team.
Users browsing this forum: No registered users and 142 guests
