esp-wroom-32 socket
ffb_boy_30
esp-wroom-32 socket
Postby ffb_boy_30 » Thu Dec 05, 2019 8:05 am
I'm making a pcb board and I'm looking for the spring pin to connect the esp board .
like on this board
https://www.aliexpress.com/item/33004018313.html
impossible to find the name of this kind on plug connector.
burtrum
Re: esp-wroom-32 socket
Postby burtrum » Thu Dec 05, 2019 4:02 pm
Hi I know these spring pins as "frogo" pins.
A search found lots of frog shaped broachs !
Good luck.
Burtrum
ffb_boy_30
Postby ffb_boy_30 » Thu Dec 05, 2019 6:26 pm
Thanks,
I was looking for the good terms for a while.
When I search
https://www.google.com/search?q=frog+sh ... nector+pcb
I don't find anything , only frog broachs :D :D :D
ffb_boy_30
Postby ffb_boy_30 » Thu Dec 05, 2019 7:19 pm
I've found a pcb called frogboard but it is not the real name of the socket connector pin
ffb_boy_30
Postby ffb_boy_30 » Wed Dec 11, 2019 1:07 pm
I've found the same system on the XBEE SMD dev board. but it is a propriatary socket
https://www.digikey.fr/product-detail/f ... ND/3481914
Don't found the esp32 contact
TheVisionariesInk
Postby TheVisionariesInk » Sat Mar 12, 2022 5:55 pm
Not sure if you found a source.
I have been able to find one supplier: https://www.solder.party/docs/flexypin/
If you find any more, please post here.
Users browsing this forum: No registered users and 64 guests
