ESP32-PICO-V3 IO20 error
AG1702
Postby AG1702 » Fri Sep 03, 2021 7:53 pm
I have an issue using ESP32-PICO-V3 IO20 (pin 27). When executing, terminal says:
E (317) gpio: gpio_set_direction(263): GPIO number error
E (327) gpio: gpio_set_level(215): GPIO output gpio_num error
Here's the simplest blink example I'm using.
#include <stdio.h>
#include "freertos/task.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
#define LED 	GPIO_NUM_20
#define RET	500
void app_main(void)
    gpio_pad_select_gpio(LED);
    gpio_set_direction(LED, GPIO_MODE_OUTPUT);
    while(1)
    	gpio_set_level(LED, 1);
        vTaskDelay(RET/portTICK_PERIOD_MS);
        gpio_set_level(LED, 0);
All other IO pins work fine.
Someone knows what's happening?
Sin título.jpg (166.15 KiB) Viewed 3340 times
boarchuz
Re: ESP32-PICO-V3 IO20 error
Postby boarchuz » Fri Sep 03, 2021 8:03 pm
IO20 wasn't available on earlier packages, so it was considered invalid. Support was added in IDF very recently, so you'd have to pull in/copy the latest changes to use it:
https://github.com/espressif/esp-idf/co ... 21fd142b79
AG1702
Postby AG1702 » Tue Sep 07, 2021 6:30 pm
SOLVED. Thank you very much.
Users browsing this forum: No registered users and 40 guests
